Author Topic: CB400F Carburetor Thorttle Cam Split After Electroplating  (Read 2511 times)
Offline RickB
    • Pop Magazine
« on: April 28, 2013, 07:05:11 AM »
Hi guys,
So I drilled out the retaining pin on a spare CB400F carb rack and removed the throttle cam and sent it off to get electroplated.
I went to put it back together and it fell to pieces on me!
It appears the electroplating process has eroded the rivets that hold the cam that the push/pull throttle cables connect to. It's a two part thing which is under a bit of stress, so I want to 'fix it' correctly whilst respecting originality. Obviously I could just bolt them back together but I want to do it the 'right' way.
Has this happened to anyone else and/or can you tell me how Honda originally fixed these two pieces together?
Thanks,
Rick.
Offline RickB
    • Pop Magazine
Re: CB400F Carburetor Thorttle Cam Split After Electroplating
« Reply #1 on: April 30, 2013, 08:21:12 PM »
Nobody? Surely I can't be the first person this has happened too?
Offline Reganator
  • Just another guy with a CB750 kinda cafe.
« Reply #2 on: April 30, 2013, 09:51:59 PM »
Duck tape.
Just kidding.  That's weird... I'm wondering why it would have come apart... don't they put the parts in some kind of acid when they electro plate them?  Maybe it didn't like the rivets... I dunno... frankly if it were me I'd try to find new or take it up to my friend's place to get tacked on with a tig welder.  Maybe even try JB weld in a pinch.  I don't think that thing would see all that much direct stress, or at least that much in the downward direction onto the joint between the two plates.
Frankenbike CB750:
71 K1 Frame
72 K2 Engine
75 F0 Carbs:
     #40 slow jets
     #105 Main Jets
     Stock needle and settings.
My-neighbors-love-me-Kerker 4 into 1
Stock airbox
The best way to make a small fortune on the stock market is to start out with a large fortune.  Trust me, I'm an actuary.
« Reply #3 on: April 30, 2013, 10:07:13 PM »
It is either a spot weld or pressed in a die. There is a process called fineblanking, where they press partway thru the metal blank...allowing stacking together without movement. This same process can probably be used to assemble parts if it is carefully controlled. If you pressed it back together, will it stay put after zssembly..ie, a nut holds it tight to a shoulder.
Offline kghost
« Reply #4 on: April 30, 2013, 11:09:59 PM »
Or you could rivet it back together.......
Take it out to the local small flying field and find a A&P mechanic.....he should be able to put a couple aluminium rivets in it
Stranger in a strange land
bollingball
« Reply #5 on: May 01, 2013, 07:17:52 AM »
HARISULUV@GMAIL.COM
He could get you one Member here rebuilds carbs
Ken
Offline RickB
    • Pop Magazine
« Reply #6 on: May 02, 2013, 05:29:41 AM »
Thanks guys.
I'm not looking to replace it, as I have had it plated and the whole point in taking if off the cam in the first place was to plate it and avoid it rusting.
I'm thinking I'll rivet it or take my bike to an engineering shop and see if we can determine how the original was done.
I'll report back here with what I find.
