Author Topic: Stainless steel kits  (Read 1476 times)
Offline jamesb
« on: April 29, 2013, 04:44:27 PM »
What's the best ones to get for the cb750 I'm looking for the Allen head ones. I'm changing everything over to stainless steel nuts and bolts on my chopper. And the engine is the last thing I've done so now I'm ready. I was wondering what's the best set to use if any ody has feedback on it thanks.
Re: Stainless steel kits
« Reply #1 on: April 29, 2013, 04:56:44 PM »
Dime city cycles
Offline RSchaefer
« Reply #2 on: April 29, 2013, 05:07:33 PM »
Make sure you use anti-seize, the correct anti-seize, I'm thinking not the copper based stuff, I may have that mixed up, would have to look at my notes.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline lucky
« Reply #3 on: April 30, 2013, 08:44:43 AM »
Correct, you do not want copper next to the aluminum.
Offline tool14
« Reply #4 on: April 30, 2013, 11:46:01 AM »
working class choppers nice sets
Offline stereosilence
  • 1975 CB550K
« Reply #5 on: April 30, 2013, 11:53:00 AM »
I got mine from a member here. Check the services section.
Offline ncstatecamp
« Reply #6 on: April 30, 2013, 12:09:00 PM »
Uh #$%*.... Care to elaborate?
Offline RSchaefer
« Reply #7 on: April 30, 2013, 04:16:20 PM »
There are two different types of anti-seize, you should not use the one with the copper additive for stainless and aluminum.  For instance you would NOT want to use this http://www.amazon.com/Permatex-80078-Anti-Seize-Lubricant-Bottle/dp/B000AAJTXY
But you WOULD want to use this http://www.grainger.com/Grainger/LOCTITE-Anti-Seize-Compound-4KM51
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
bollingball
« Reply #8 on: April 30, 2013, 05:50:14 PM »
What one would you use for the stock bolts?
Offline RSchaefer
« Reply #9 on: April 30, 2013, 07:41:54 PM »
Not the Copper!  I don't remember the whole metallurgy issue, the biggest problem is with the stainless bolts, they tend to seize easily in aluminium unless you use the anti-seize.
I use anti-seize on the long seat bolts for my GL1800 Goldwing, steel bolts into aluminium.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline tlbranth
« Reply #10 on: April 30, 2013, 08:07:33 PM »
Au contraire Matey, you do indeed want to use copper antisieze.
Here is the advice fom INOX UK
Why is it really that important to use copper anti seize and not something else?
When stainless steel is fastened ‘dry’ into Aluminium, galvanic corrosion can occur as the result of two different materials at opposite ends of the ‘metal nobility’ table being interfaced. In practical terms this means that alloy crankcases can oxidise around the fastener area very quickly. Copper based anti seize provides a third metal as the ‘sandwich’ and, as copper is placed in the centre of the ‘metal nobility’ table, it prevents Galvanic corrosion. Ordinary grease or oil will not work as they do not contain the vital element. UNDER NO CIRCUMSTANCES use Aluminium grease of any sort - including aerosols - as it will probably seriously damage the castings.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline tlbranth
« Reply #11 on: April 30, 2013, 08:40:16 PM »
Jamesb. I don't know if this would be of interest to you but......I went to the parts fiche for my bike and wrote down all the bolt sizes I was interested in and whether I wanted regular bolts or allen-head. Then I ordered everything from here:
http://www.boltdepot.com/Catalog.aspx?wt.srch=1
A bit cheaper than the bike suppliers. Also, you can get a bag of ss washers pretty cheap there.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline ncstatecamp
« Reply #12 on: May 01, 2013, 11:57:24 AM »
looking at the website the permatex stuff is a mix of copper, aluminum, and graphite. So did I #$%* up or what?
bollingball
« Reply #13 on: May 01, 2013, 12:09:50 PM »
I did read this awhile back now I don't know what is correct :-\ More research needed. I have always used the silver stuff and never look at the label.
Ken
Offline RSchaefer
« Reply #14 on: May 01, 2013, 12:10:38 PM »
Honestly the issue of copper based anti-seize comes up primarily as it relates to stainless screws, bolts, etc, not the stock bolts.  It seems typical to use a copper based anti-seize in aluminum heads for spark plugs, so I think the copper based stuff is fine for stock fasteners.  The issue is more to do with copper based anti-seizes and the use of stainless fasteners.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline jamesb
« Reply #15 on: May 01, 2013, 03:01:15 PM »
Thank you guys for all the info and links I'm going to make my move next week and start getting my stainless steel nuts and bolts. I've replaced all of them on the bike the engine is the only thing left. I would like to find SS clamps for the carb boots. I have to have my sissy bar custom made to fit this bike I'm having it done in SS also.
