Author Topic: CB550 F Airbox rebuild  (Read 1204 times)
Offline TimD550
« on: May 02, 2013, 01:13:54 AM »
Hi all,
I am putting my CB550F airbox back together but I need some advice as it was all in pieces when I got it.
I have some airbox foam to replace the paper filters which would have been on the original bike.
Do I need to oil this foam or do I just stick it in the relavent areas?
I see there is a breather tube which should attach the the bottom of the airbox. Is it important to have a tube attached or can it be left off? If it is required would a piece of fuel line suffice or do I need the real deal?
Thanks!
1977 CB550 F
Offline Gman
Re: CB550 F Airbox rebuild
« Reply #1 on: May 02, 2013, 01:35:35 AM »
http://forums.sohc4.net/index.php?topic=86697.100
Check out Sohron's rebuild.  Page 5 has everything you need to know and is super well documented ( both the write up and pics).  It's actually worth reading the whole thing, as it is both entertaining and informative.
Good luck!
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline TimD550
« Reply #2 on: May 02, 2013, 02:22:33 AM »
Awesome.
Thank you, Gman!
1977 CB550 F
