Author Topic: Will it fit?????  (Read 2895 times)
kansassteve
Will it fit?????
« on: May 16, 2005, 05:46:03 PM »
I have a 1974 CB 550. Will a set of carbs from a 1972 CB 500 fit ?? Thank you, Stephen.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Will it fit?????
« Reply #1 on: May 16, 2005, 05:56:25 PM »
I get asked that question all the time  :o
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #2 on: May 16, 2005, 06:27:52 PM »
Yes they will fit,actually they are the same carb bodies.I run `74 550 carbs on my `72 500,I just used the jets and needles from a 500,so you might have to rejet.500 has 100 main and 40 idle jet and I think the 550`s jets were smaller.
Stephan
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #3 on: May 17, 2005, 09:48:04 AM »
I have 71' 500 carbs on my 75' 550 , and mine had 38 idle jets stock, which I bumped up to 40s. I think I am going to drop them back down, I seem to be idling rich.(which may not be the only issue)...
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
« Reply #4 on: May 17, 2005, 12:47:31 PM »
They will physically fit, yes.  But, there are different carb setups to match the model.  The setups are stamped on the carb body mount flanges. I have a chart with the setup specifics I know about.  It should be an attachment.  But, this is my first try doing that on this site.  Let me know if it works.
El Taco
« Reply #5 on: May 17, 2005, 07:21:23 PM »
I've used the same set of CB550 carbs on three different 550s and now on a 500 over the last 5 years. Bikes have all run great with no rejetting or sync.
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #6 on: May 18, 2005, 09:50:00 AM »
Thanks for the chart Lloyd, downloaded,printed and in my folder..what are its origins??
SOHC Member#4000
78' 550
73' CL175
« Reply #7 on: May 18, 2005, 11:29:29 AM »
I created the chart with data collected from the Honda shop manual and its supplements, direct observation of my bike collection, and discussions with SOHC4 list members.  I only put data in there that I had some confidence about veracity.  I've heard about, but have never seen, Honda supplied booklets for their dealers/shops that specified the components for each carb setup that was supplied by the production facility.  I was never able to convince those who were quoting those books to make copies or somehow get them into the public domain for us restorers and old bike aficionados.  What a pity.
kansassteve
« Reply #8 on: May 19, 2005, 07:32:13 PM »
Thanks for the table, really useful information. Why don't you place it under the FAQ's ?? Thanks again, Stephen
