Author Topic: ss brake line cb650  (Read 3671 times)
Offline davesee
ss brake line cb650
« on: May 04, 2013, 02:01:37 PM »
i'm looking to get a stainless steel brake hose for 1980 cb 650. does anyone know if a later model cb750 hose would be interchangeable (perhaps '78)? if not, any suggestions where to look for one?
thanks
1980 honda cb650 with many weekends worth of modifications.
Offline wowbagger
  • Not much of an
Re: ss brake line cb650
« Reply #1 on: May 04, 2013, 06:43:50 PM »
Check out Slingshot Cycles. Got a set from him for my CB500. He even gives a discount to forum members.
Offline davesee
« Reply #2 on: May 05, 2013, 04:20:46 AM »
that's where i was hoping to get it from, but there is no cb650 listed. there's a '78 cb750, but i'm not sure if the fittings are the same, as the m/c is different i think.
Offline wowbagger
  • Not much of an
« Reply #3 on: May 05, 2013, 04:43:10 AM »
He does custom lengths. Just get in touch with him and let him know what you are looking for. He may already know the lengths and fitting needed for that bike.
Offline davesee
« Reply #4 on: June 13, 2013, 05:17:47 PM »
i'm still on the hunt for this brake line...slingshot didn't pan out. does anybody have a 1980 cb650 that runs a stainless steel hose? or know if another model uses the same hose?
« Last Edit: June 13, 2013, 05:20:37 PM by davesee »
Offline tomkimberly
« Reply #5 on: June 13, 2013, 09:53:04 PM »
I ordered the parts from Z1 for my 81 CB650 Custom. Just measure the lengths you need and place your order.
Tom
Offline ShermanPain
« Reply #6 on: June 13, 2013, 11:14:35 PM »
I ordered an SS cable from slingshot 2 weeks ago for my 1980 650c and Shawn was able to make it up for me no problem. I have superbike bars and he made a custom length. 65 bucks I think and definitely worth it.
1980 CB650C
Offline davesee
« Reply #7 on: June 14, 2013, 02:26:53 AM »
i really wanted to get it from slingshot, but i waited for six weeks to hear back from him, and he said he didn't have a cb650 standard cable to use as a template. i asked whether pictures and measurements would suffice, but that was two weeks ago and i haven't had a response, and i'm getting a little impatient. i'll give him one more try today.
Offline ShermanPain
« Reply #8 on: June 14, 2013, 09:21:33 AM »
He would sometimes go a week without responding but when it actually came to making up the line it only took him a day. You could help him out my measuring the length of your cable, and take pics of your MC and the fitting on the cable. Thats what I did and Shawn had no problems, the cable fit perfectly.
1980 CB650C
Offline jefe06
« Reply #9 on: May 28, 2019, 05:59:21 AM »
Bump.
Has anyone had any contact with Slingshot-Cycles?  I'm looking to get a set for my 81 CB650, but the pricing for everything I'm finding is pretty steep.
1981 CB650C bone stock.
« Reply #10 on: May 28, 2019, 08:36:42 AM »
He is on "hiatus"!
Contact Apex....
http://www.apexbrakes.com/custom.asp
Offline Bankerdanny
  • Endeavor to persevere
« Reply #11 on: May 28, 2019, 09:28:27 AM »
I just got lines for my 750 from Venhill USA via Ebay.
The lines use screw on type banjos into AN type fittings crimped on the hose, so you give them the overall length and specify if you need straight or bent banjos and they send you the hose with the ends crimped on and you then screw in the banjos and take care of clocking. I paid $117 shipped for 3 lines (master to splitter and 2x splitter to calipers).
Everything installed easily and I was very happy with the communication with the seller to make sure I got what I needed.
https://www.ebay.com/itm/Venhill-Braided-Brake-Line-Kit-6-32-Inches-Long-Banjo-Fittings-No-Bolts/112908770674?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Offline jefe06
« Reply #12 on: May 28, 2019, 12:34:41 PM »
Thanks for the info guys.  Bankerdanny, so when I go to ebay do I just purchase 3 units (master to spliter, spliter to 2 x calipers) from the vendor and they will contact me to determine the length, type, and color of connections I need?
Offline DaveBarbier
« Reply #13 on: May 28, 2019, 04:48:09 PM »
I decided to use this kit from Revival Cycles. I was a little dubious about it but after using it and how easy it was to install/make I’d do it again on my next build.
Offline jefe06
« Reply #14 on: May 29, 2019, 06:23:08 PM »
Dave what did it run you if you don't mind me asking.
Offline DaveBarbier
« Reply #15 on: May 29, 2019, 06:51:11 PM »
Don’t remember exactly but in the description of the video there’s the link to buy.
Offline Bankerdanny
« Reply #16 on: May 29, 2019, 07:33:06 PM »
You need to measure your original lines to get the length information from them and include the data with your order.
Offline jefe06
« Reply #17 on: May 30, 2019, 05:09:46 AM »
10-4.  Thanks guys.
Offline jefe06
« Reply #18 on: June 20, 2019, 05:06:26 AM »
One more quick question.  I am placing my order for the brake lines and the seller is asking me if I need banjo faces even with each other or one rotated 45, 120, 180 in relation to the other.....  Will ordering the correct length brake lines and banjos even faced work fine, or do I really need to take these into consideration.
Offline Bankerdanny
« Reply #19 on: June 20, 2019, 05:37:33 AM »
You do need to know this. Brake hoses don't twist well.
Offline DaveBarbier
« Reply #20 on: June 20, 2019, 05:55:47 AM »
+1
One reason I like the Revival kit. You can really play with it and get your lines to route smoothly with no tension.
Offline Autoground
  • 1980 CB650c
« Reply #21 on: July 21, 2020, 05:19:54 AM »
Posting for help to anyone googling:
I measured the length of my 1980 cb650 brake line hose, and it was 43" , or 109cm.
I might buy from Spiegler, and the order would look like this:
Caliper End - fitting type 002
Top end - type 530
Grommet at 54”, 2cm by 2cm
Price pending (they make me request an email :(
I might buy from Apex
Caliper End - type #3
Top end - type 9
$50
Good luck everyone, and good luck me.
« Last Edit: July 21, 2020, 06:08:58 AM by Autoground »
1980 CB650c
Offline onepieceatatime
« Reply #22 on: July 21, 2020, 04:27:50 PM »
Thanks for the info. I need to order stainless lines too, at some point, but had not gotten around to measuring yet.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Bankerdanny
« Reply #23 on: July 21, 2020, 09:12:48 PM »
My last 2 sets of SS lines came from Venhill USA. $100 for 3 lines shipped. Venhill uses screw on AN banjos, so you clock them at installation.
Offline Autoground
  • 1980 CB650c
« Reply #24 on: August 07, 2020, 02:10:35 AM »
I am sad to say that Apex brake lines' fixtures do not match the threads of my 1980 cb650c. The only fittings offered are 10mm 1.0, which doesn't fit.
As far as I can tell, Spiegler is really the only option, and they still haven't replied to my quote request, so I can't actually buy it yet. :(
1980 CB650c
