Author Topic: ss brake line cb650  (Read 3670 times)
Offline Bankerdanny
  • Endeavor to persevere
Re: ss brake line cb650
« Reply #25 on: August 07, 2020, 09:53:46 AM »
I am sad to say that Apex brake lines' fixtures do not match the threads of my 1980 cb650c. The only fittings offered are 10mm 1.0, which doesn't fit.
As far as I can tell, Spiegler is really the only option, and they still haven't replied to my quote request, so I can't actually buy it yet. :(
You should be able to reuse your original bolt.
Offline maxheadflow
« Reply #26 on: August 08, 2020, 03:10:35 PM »
What I end up doing is going to drag specialties, parts unlimited or tucker rocky and order the parts pretty much from any on line parts supplier that uses those distributors.   You can get hoses in any 2 inch increments. I use an-3 fittings an convert the calipers to take  10x1.25 banjos.  If down the road, you need another line, only have to buy the line.
http://asset.lemansnet.com/static/sites/dragspecialties/flipper/2020_21_oldbook_v2/
http://asset.lemansnet.com/static/sites/partsunlimited/flipper/2020_street/
http://online.fliphtml5.com/lxnd/ugjv/#p=1
I use a guy named California Phil to by parts from.
https://harleypartscheap.com/
but I've used other guys also.
The CB750s used 10mmx1.25 mm banjo bolts for the calipers.
One line, 2 banjos, and 2 bolts is about $85-90 and you can get about a 10-20% discount on that depending on who you buy through.
« Last Edit: August 08, 2020, 03:15:13 PM by maxheadflow »
