Author Topic: rear hub 1978 cb550  (Read 951 times)
Offline uksparky
  • Track days
rear hub 1978 cb550
« on: May 04, 2013, 02:22:22 PM »
Has anyone replaced the rubber dampers in the rear hub...today i pulled the rear wheel thinking i could pull the sprocket and there they would be lol.... :(   seems there is a flange/bearing retainer stopping me pulling them out..any help guys..
Present bike 1982 900C Custom
Re: rear hub 1978 cb550
« Reply #1 on: May 04, 2013, 04:22:59 PM »
In 30 years never seen any worn out yet
« Reply #2 on: May 04, 2013, 04:40:26 PM »
Here is a pic of a '77 750 hub; I believe the 550 is similar? The sprocket and drive plate should pull straight out of the hub as a unit. The drive plate has it's own bearing; be sure to check that as well.
Offline uksparky
  • Track days
« Reply #3 on: May 04, 2013, 05:29:05 PM »
Thanks guys ...i got it apart ..the flange screws off anti clockwise..bearings ok....the rubbers are intact but there is some wear in the rubbers causing a bit free play when the hub/sprocket is on
Offline uksparky
  • Track days
« Reply #4 on: May 04, 2013, 08:48:15 PM »
not worn out but hard as rock...could play tennis with them lol..34 years old
Update 5/5...i decided to cut some thin hard rubber to take up the slack in the hub/dampers..now the hub is back together, everything is tight now....waiting for new brake shoes...
« Last Edit: May 05, 2013, 05:06:59 PM by uksparky »
