Author Topic: Packing shorty reverse cone mufflers?  (Read 6241 times)
Offline Scott S
« on: May 05, 2013, 05:16:08 AM »
 I have a set of the shorty, 17" reverse cone mufflers on the way soon. The pics are nabbed from ebay, but they're the same mufflers.
 One common complaint about these mufflers is that they're loud. It looks like the end cap is removable. Has anyone tried wrapping the baffle with fiberglass muffler wrap or packing to muffle the sound a bit? Not wanting to choke 'em or completely silence them, but I was wondering if a little muffler packing would mellow the sound a bit?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Gordon
  • 750K1, 550K2
Re: Packing shorty reverse cone mufflers?
« Reply #1 on: May 05, 2013, 07:27:09 AM »
I had those on my 360.  Wrapping the baffles with fiberglass didn't make much of a difference.  It took a little of the sharpness off the top, but that's about it.
Offline Scott S
« Reply #2 on: May 05, 2013, 07:49:40 AM »
 Could you tell any difference performance wise?
'71 CB500 K0
'81 Yamaha XS650
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: May 06, 2013, 07:58:47 AM »
Nope.  It's such a free-flowing exhaust that wrapping the baffles doesn't really do much of anything.  You still have the large hole at the end of the baffle that lets the sound and exhaust go straight through.
Offline lucky
« Reply #4 on: May 06, 2013, 08:31:21 AM »
Do not stuff fiberglass packing in these it just blows out all over the place and then you will be breathing it in your garage.
If you have fiberglass packing in a muffler start it up and open the garage door. You will see all the fiberglass particles  floating like glitter in the sunlight.
What is the best thing to do is put a metal baffle in the head pipe. THEN attach the reverse cone megaphone and it will reduce the sound. I have done it.
I got the all metal baffle online through Cycle Shack.
« Reply #5 on: May 06, 2013, 02:35:08 PM »
You suggest some strange sh1t for a mechanic Lucky, why would you put anything in the header pipes, thats just plain stupid....    :o
« Reply #6 on: May 06, 2013, 02:53:52 PM »
strangely, I kinda see where lucky is going with this  ???
some sort of insert, like a mac style baffle, just past the collector, right where this slip on fits. (not in the header)
just adding another point of resistance to quiet it down, and one more thing to tune for  ::)
« Reply #7 on: May 06, 2013, 03:29:58 PM »
I would be more inclined to but some baffle material and make a slightly smaller diameter baffle and do it properly, any restriction further up the pipes is going to effect power pulses and tuning, that is going backwards in my opinion....  Doesn't someone like Cone engineering have baffles...?
Offline Scott S
« Reply #9 on: May 06, 2013, 04:59:26 PM »
There's lots of proper packing around...
http://www.ebay.com/itm/1-4-20-x-38-TECHMAT-MOTORCYCLE-EXHAUST-MUFFLER-PACKING-WRAP-/140969457574?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item20d26f37a6
 That's the stuff I was talking about using. I've seen it wrapped and taped. The mufflers don't get super hot like the headers....wonder what tape would hold up best?
'71 CB500 K0
'81 Yamaha XS650
« Reply #10 on: May 06, 2013, 06:26:58 PM »
The tape is just to hold the packing in place when inserting the baffle into the muffler. I've even used masking tape! You actually want the tape to fail, as this will allow the packing to expand. If the packing is tightly compressed, it won't be as effective as a silencer. An absorption type silencer tends to reduce the higher frequency elements, or sharpness as Gordon stated.
The design of the baffle also can make a difference; the size /shape/number of perforations, and the length of the perforations in the tube. When you get the mufflers, pull them apart and see what you have to work with.
Here's a pic of the baffle from my bike, with a good portion of the 'glass burned out.
