Author Topic: do the index lines on an aftermarket cam still hold any merit?  (Read 729 times)
Offline Turbogrimace
    • Draft Cycle Works
I'm serting up a 125-75 and started with the index lines. I was going to go from there and set it based on the lobe centers, but after followng the index lines and pulling evertthing back 105* to set the intake lobe center, its no where near the top of the lobe.
    • Draft Cycle Works
Re: do the index lines on an aftermarket cam still hold any merit?
« Reply #1 on: May 05, 2013, 06:34:54 PM »
Got it. Thanks again mike rieck. With the cylinder and the head being decked, along with several other factors. The cam is set about 2 degrees off of the stock index configuration.
So... Yes. Yes they gots that merit.
