Author Topic: Fuses: if I don't have correct amps fuse, best to replace with higher or lower?  (Read 780 times)
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
Blew the main fuse on my cb750k '78 and since today is a sunday most auto stores were closed except for an auto zone so I went there and they did not have 15 amps fuses.. they had only 20 or 9 amps fuse so I elected to temporarily use 9 amps fuse for the main fuse to get home, over the 20.
I referred to the chart attached where the fusebox is listed as 7-15-5, but the fusebox on my bike is listed as 5-7-15, in that order.
My question is, was it smart to temporarily use a 9 amps fuse just to get the bike home, rather than a 20 amps where a 15 amps was needed? What should I do for next time if I don't have spare fuse handy, or have the wrong amps fuse?
« Last Edit: May 05, 2013, 03:01:43 PM by deafcaferacer »
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
Offline afkrejci90
Well if you got it home with the 9 amp fuse, then no harm done.  Using a higher amperage fuse could lead to problems especially if you have a short, but then could again pop the fuse anyways.
Get a spare fuse holder and mount it somewhere on your bike, that way you always have one handy.
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
