Author Topic: CB400 Levers question  (Read 717 times)
Offline 74CB400FFourSS
  • Cafe for life
  • 75 CB400F Super Sport
« on: May 06, 2013, 04:34:48 PM »
Does anyone know if the clutch and brake levers, (just the levers) from 92-08 CB400 will work with a 75-77 CB400f? I found a set of aftermarket short adjustable levers for the 89-08 CB400. I want to get them and use them on my 75 CB400F SS controls. I'm building a cafe racer and these would be a sweet addition to it. If anyone knows if the levers are the same please let me know.
thanks,
« Last Edit: May 07, 2013, 02:39:29 PM by 74CB400FFourSS »
Rob
1975 CB400F Four SS
  • Cafe for life
Re: CB400 Levers question
« Reply #1 on: May 07, 2013, 02:40:03 PM »
bump
Rob
1975 CB400F Four SS
Offline Powderman
« Reply #2 on: May 07, 2013, 03:48:50 PM »
Go to Ebay and look at listings for both and you will see they are different and probably won't interchange. I know for sure the brake lever is different. and the top recess is different on the clutch lever also.
  • Cafe for life
« Reply #3 on: May 07, 2013, 08:05:56 PM »
I did that before I even posted this. They looked slightly different but you never know if they're actually showing you a pic of the correct levers. Thanks for the info though, I'm a lil bummed but found a beautiful set of aftermarket cnc aluminum levers with adjustable master cyl but I'll have to get new electric controls if I go that route and was trying to avoid that. Dime city has some but they were not really the look I was going for.
Rob
1975 CB400F Four SS
