Author Topic: Where does the tail light on a 76 CB550k draw it's power?  (Read 910 times)
Offline CapeCafe
« on: May 09, 2013, 06:46:17 AM »
I know I have been asking this same question a number of different ways, but I am bound and determined to figure out why my tail light and tach/speedo lights do not work with the ignition on?  I've tested the ignition switch per the manual and it passes.  I have the clutch side controls apart and trying to find out how the Brn/Wht wire (which powers the tach/speedo and tail light) gets powered.  I have continuity through the Brn/Wht wire from the circut board inside the control, through to the main wiring harness.  Which wire brings power into the left side control?  Again, I apologize for asking the same question, but I'm sure someone out there knows the answer.
For the sake of time, I do know the Brn wire goes directly from the ignition switch through the 5amp fuse to the tail light.  but that only powers the tail light in "parking mode" position 2.  Thanks
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
1995 Ducati 900 SS/SP
2000 Ducati 900i.e.
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
Offline Dave Voss
Re: Where does the tail light on a 76 CB550k draw it's power?
« Reply #2 on: May 09, 2013, 08:06:18 AM »
The tailight is always (and only) energized through the brown wire, through the fuse, from the ignition switch.  When the ignition key is in the 'Park' position, battery voltage is fed from the red wire through the ignition switch to the brown wire.  When the ignition key is in the 'On' position, battery/alternator voltage is fed from the brown/white wire through the ignition switch to the brown wire.  The brown/white wire also energizes the instrument lights, so if they are not working either, then the problem is that your brown/white wire isn't getting voltage.
On earlier models with an 'On-Off' switch for the lights, the brown/white wire is energized when the ignition key is 'On' and the light switch is 'On'.  On later models without an 'On-Off', the brown/white wire is energized when the ignition key is 'On'.  I believe 1976 was the last model year that had an 'On-Off' switch for the lights, and 1977 was the first model year without it, so depending on the date of manufacture, yours may or may not have one.  If it does, the black wire at the 'On-Off' switch should be energized when the ingition key is 'On'.  If the black wire has no voltage, check for loose wiring connections behind the headlight (inside the housing).
The brown/white wire also provides voltage to the turn signal switch, so check to see if they are working.  If so, then check for loose brown/white wiring connections behind the headlight (inside the housing).  If the turn signals are also not working, check the wiring connections at the ignition switch and its harness connector.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Offline CapeCafe
« Reply #3 on: May 09, 2013, 09:29:34 AM »
Awesome!  Thanks for the detailed answer.  I will track through and see what I can uncover as my problem.
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
Offline 55 Truck
« Reply #4 on: May 09, 2013, 11:28:58 AM »
I was having the same problem with my CB550F SS. Here is a link to the responses I received and what I ultimately wound up doing.....>>>>   http://forums.sohc4.net/index.php?topic=121278.0
Offline CapeCafe
« Reply #5 on: May 09, 2013, 01:04:07 PM »
Thanks 55 Truck.  I did see your post earlier and did jump the surplus Brown connector in the HL bucket to the Br/Wh and it did give me TL and tach/speedo lights with the ignition on.  Unfortunately I blew the TL fuse when I switched the ignition to 2nd position (parking).  I'm determined to figure out where I'm loosing continuity through the Brn/Wh and get the bugger to light the way it was meant from the factory.  If push comes to shove I can always jump them again to get a MA inspection sticker if I don't figure it out soon.
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
