« Reply #2 on: May 13, 2013, 10:15:33 AM »
hello all, i have a question about seafoam. there are two kinds the one u put in the gas and the other that u inject right in the gas line. i have a stuck float on the number 2 carb of my cb350f and about a half ounce of fuel spits out every 15 seconds of the overflow. my question is, can i put the seafoam spray up into the overflow tube to try and get the float unstuck and/or cleaned and then run a carb cleaner seperate in the gas or would that not be a good idea. ANY HELP WOULD BE GREATLY APPRECIATED.....thanks
-clint
^ thats the important stuff..
is it ok to use Seafoam?
YES.
will it clean your carbs to the point you wont have any issues, and wont need to clean them properly?
NOclean your tank of debris, clean your carbs properly, and attend to your carb float/float valves.
« Last Edit: May 13, 2013, 10:23:37 AM by flybox1 »
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
