Author Topic: XR1327 LSR Sportster Cafe Racer  (Read 24318 times)
Re: XR1327 LSR Sportster Cafe Racer
« Reply #50 on: September 16, 2013, 02:32:17 PM »
Powderman, buke looks Super Deluxe  8)
Buke? Puke? I'm confused............... ;D
Offline knowsnothing
« Reply #51 on: September 17, 2013, 11:21:56 AM »
Buke: (verb) When you go to burp and a little puke comes up.   ;)
1978 CB750k Blue - for sale
« Reply #52 on: September 17, 2013, 01:30:45 PM »
U is beside the I on my keyboard and given I was posting from my tablet with a touchscreen keyboard, it was an easy typo to make...
buke, bike, boke...could have been any of those with that letter reached too far or on target...
bije, bike, bile
bikw, bike, bikr
Other Examples of errors on another letter
« Reply #53 on: September 18, 2013, 03:04:31 AM »
Tablet eh? I'm not much into high tech, but my wife is. The other day I asked her to pass me the newspaper and she said, "You old Dinosaur, no-one reads newspapers anymore, check this out!" and she passed me her tablet. She was right too, that spider on the wall didn't see it coming! ;D
« Reply #54 on: September 18, 2013, 08:20:34 AM »
Is it just me?but I would gladly take an XR 750 over a CR750.. Any day of my life..
Offline Powderman
« Reply #55 on: September 18, 2013, 01:26:54 PM »
bije, bike, bile
bikw, bike, bikr
I knew what you meant and what happened the first time. Thanks
Offline Powderman
« Reply #56 on: September 18, 2013, 01:28:48 PM »
I'm with you buddy. I'd love to have a CR750 only if I could park it next to my XR750 which is parked next to the XRTT750.
« Reply #57 on: September 18, 2013, 07:54:34 PM »
The XR 750 is the best looking Harley ever made, IMHO. I fell in love after seeing it on the cover of a magazine back in the day.
« Reply #58 on: September 20, 2013, 12:48:32 AM »
No, it's not just you Frank, I fell in love with XR750's when I saw Evel Kneivel jumping over cars and buses with them. (and occasionally into them...........) A big V Twin with the power of a Ducati but with the reliability and simplicity of a Harley is a wonderful thing! ;D
Offline Powderman
« Reply #59 on: September 22, 2013, 03:45:30 PM »
So I go to put the chain on tonight only to find that with the 23T sprocket the chain hits the boss where the lower cover dowel pin is. I am going to have to grind some clearance there.
« Reply #60 on: September 23, 2013, 12:37:55 AM »
Probably a stupid question mate, but is that sprocket on the right way around mate? it looks like it could be offset a few mm's? Cheers, Terry. ;D
« Reply #61 on: September 23, 2013, 07:26:54 AM »
Terry they have a seal lip surface on one side..  The inside is where that goes, pretty much one way deal.. Hope he gets it fired soon..
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #62 on: September 23, 2013, 09:30:29 AM »
In for the lurk. Love Hondas, but Harleys can be cool too :)
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline Powderman
« Reply #63 on: September 26, 2013, 09:29:12 AM »
I changed all the original barb fittings over to AN fittings for the oil lines because it is a more mechanical and cleaner looking setup than hose clamps and easier to remove and install. That and they just plain  look cool. I hear they are worth 10hp and 4mph. ;D
The gas lines are Braided Steel Teflon with snap clamps that worked nicely.
« Reply #64 on: September 26, 2013, 08:33:30 PM »
I've just found this, what a cool project!
+1.  Cant believe I havent seen this before, very cool.
Offline Powderman
« Reply #65 on: September 27, 2013, 05:09:30 PM »
Shortened shift lever. Feels right but won't know till I try it with the race boots on:
Reset the rear intake manifold angle to bring that carb in tighter to the bike:
If it's not one thing, it's another. I have to replace the steering stabilizer with one with a shorter body. This one bottoms the stabilizer before they hit the fork stops:
« Reply #66 on: September 27, 2013, 09:24:52 PM »
Try swiveling the fork clamp outward... That masterlink gotta go..man..
Offline Powderman
« Reply #67 on: September 27, 2013, 09:45:18 PM »
Go over to DTT and in the project thread look for the build thread of Ichiban Moto where he explains how the colored zip ties are much stronger than the white ones. All I need is to change to one of my blue or black ones and I'll be fine. This stabilizer only has about 4" of stroke, I think I need more stroke (don't we all ;D), so I'm not sure swiveling the clamp will fix it but I'll check tomorrow.
« Last Edit: September 27, 2013, 09:48:32 PM by Powderman »
« Reply #68 on: September 27, 2013, 09:54:40 PM »
Sounds lke it has to move inward..less radius means it moves less distance..
 You need a hammertone zip strap..
Offline Powderman
« Reply #69 on: September 27, 2013, 10:01:11 PM »
The fork itself moves more than 4"s in it's arc so no matter where the clamp is the shaft itself can't move through the body sufficiently.
I'm looking at this damper that has a 5.5" stroke, should fix it:
http://www.ebay.com/itm/200922947344?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
« Reply #70 on: September 27, 2013, 10:51:30 PM »
Your fork moves 4 inches but how far does the steering stop move.. Think about that..
Offline Powderman
« Reply #71 on: September 27, 2013, 11:37:39 PM »
I don't know what you mean. The steering stop doesn't move.
« Reply #72 on: September 27, 2013, 11:53:29 PM »
Think of a stock lower tree, or just draw it on paper.
 The fork tube is a greater distance from pivot, than the steering stop nub..
So..then moving the tree in the same arc, the smaller radius feature moves less distance than the one with the larger radius.
 That is why n some Honda trees there is a damper mount built in....inboard of the fork tube..
Offline Powderman
« Reply #73 on: September 27, 2013, 11:59:36 PM »
I see where if the rod on the clamp was on the inside of the fork it would have smaller radius than if it were on the outside of the fork. I don't think it will make enough of a difference in this case. My fork stops are internal inside the neck of the frame and on the steering stem itself.
Offline ThomasD883
« Reply #74 on: September 04, 2014, 06:55:41 AM »
Anyone know what became of Powderman's project? I was really looking foreward to a running video.  :(
Diesel deeds, done dirt cheap
