Author Topic: running fuel lines  (Read 778 times)
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
running fuel lines
« on: May 10, 2013, 06:51:23 PM »
my pet has 2 fuel line fitting one line going to carbs1&2 the other to 3&4 is that okay or should i run just one line from the pet to a tee that goes to both 1&2 then 3&4 and plug the other fitting from the pet,one line from my pet has a slower fuel flow
Offline bjbuchanan
Re: running fuel lines
« Reply #1 on: May 10, 2013, 07:02:14 PM »
No don't do that. Right now I can't pull the sources of why but if you have the dual you gotta run it. It isn't just merely one or the other kinda outlet
Offline neilc
« Reply #2 on: May 11, 2013, 05:06:47 AM »
my set of in line filters came they are large capacity and a pain to run and maintain it so the lines run down to the carbs but can do.
Offline neilc
« Reply #3 on: May 11, 2013, 05:41:04 PM »
the plaseix in lines large capacity fuel filters get brittle real quick from the gas with ethenol and then crack they are from visu filter from bike bandit save your money,i amgoing with chrome and paper cartridges
