Author Topic: 77 Cb550 Exhaust studs? Solutions?  (Read 5033 times)
Offline Lostboy Steve
« on: May 11, 2013, 05:49:53 AM »
I am a seasoned veteran of exhaust manifold studs (extraction, replacement, drilling, etc.) however I was wondering how everyone here goes about this. I have bad studs, half of them have pulled out of the head, the other half are just stripped. No idea how this happened. I was thinking of heli-coiling all of them and installing some grade 8, 6mm studs. Any other ideas. Next size maybe?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Re: 77 Cb550 Exhaust studs? Solutions?
« Reply #2 on: May 11, 2013, 07:46:10 AM »
Ok let me ask you guys this, what size length would I be looking for if I decide to use allen bolts instead of studs?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Stilltime
  • Building my Dream
« Reply #3 on: May 11, 2013, 12:18:12 PM »
The stock ones are M6x1.0 40mm long with about 12mm of equal threads on both ends.  You could try doing heli-coil and getting new OEM studs.  I just received four (needed one but ordered extras just in case) from a vendor online.  The part number is 90044-323-300, under $2 a piece.
You could use hex or Allen head bolts, but it isn't recommended.  With studs, the threads in the head aren't being tampered with each time the exhaust is pulled.  Whereas with bolts, every time you drop the exhaust you are wearing the threads and potentially doing more damage like that which has already been done on your bike from the PO.
One alternative I considered was ordering M6x1 316 SS studs, 40mm in length from McMaster and just using brass or bronze flange head nuts, but they are costy..
Hope that helps,
Chris C.
« Last Edit: May 11, 2013, 12:19:53 PM by Stilltime »
'78 CB550 - Orange Crush
« Reply #4 on: May 11, 2013, 12:59:09 PM »
Make sure you get the angle correct when you drill those stud holes ;)
« Reply #5 on: May 11, 2013, 05:41:55 PM »
Yes Sirs. I figure that the way its been going, tampering with the head is a 50/50 gamble. (half of my studs came out with the nuts) I assume it was all factory before I rebuilt it. At this point, and I am knocking the hell out of wood typing this, but hope fully by the next time I have to pull the bolts, nuts or studs, I wont mind redoing the whole thing. So for now, hopefully tomorrow I get some bolts.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6 on: May 11, 2013, 10:06:30 PM »
If they came out with the nuts then they should go back in with no issues. Replacement studs aren't expensive.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #7 on: May 12, 2013, 10:35:17 AM »
Instead of Helicoil, try Fastenal for their EZ inserts.  Much better in this application.  The EZ insert will take far more stress in-line and laterally than the Helicoil will when in aluminum and there's no little break off laying in the bottom of your hole after you run the stud down and seat it.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline grcamna2
« Reply #8 on: May 12, 2013, 11:24:38 AM »
I agree. I've used a product called "Timesert" which is an insert and locks into the original hole very well..,they've been serving the Powersports industry for a while.
« Reply #9 on: May 12, 2013, 12:01:45 PM »
So here's what I did. I went to Home Depot and got some Allen cap 6mm x 30 bolts. Tapped the problem holes (only 2) to 7mm x 1.0 and installed the aforementioned heli coils. Then I tightened everything down with an Allen t handle wrench so as to not put too much torque into them seems good and looks nice.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline grcamna2
« Reply #10 on: May 13, 2013, 07:17:11 AM »
They should be fine now. Do you feel you can put nice,even torque on all of them ? That's what I think matters...
« Reply #11 on: May 13, 2013, 02:02:23 PM »
Yeah, they tightened down nicely and don't leak.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
