Author Topic: Front brake light switch?  (Read 1590 times)
Offline persson-johan@hotmail.com
« on: May 11, 2013, 02:29:20 PM »
Hello!
I recently bought a front master cylinder from a cb 750 sohc. I dont know the exact year but its an plastic reservoir one. Im using it on one of my builds but i dont have a brake light switch for it and i cant reallly find one to order (and i dont really know what im looking for)
Doesn anyone here have a picture on a master cylinder with the switch mounted, or just the switch?
Best regards
Johan
Sweden
bollingball
Re: Front brake light switch?
« Reply #1 on: May 11, 2013, 02:37:54 PM »
It would be better if you post a pick of what you have so we will know what might go with it. Also what bike you are trying to put it on.
Ken
« Reply #2 on: May 11, 2013, 02:42:47 PM »
I wont be in the garage until monday so im trying to score some tips before that! :) The bike is a cb 750 from 81, everything except the light switch is done before putting the master on.
« Reply #3 on: May 13, 2013, 05:23:08 AM »
Alright, here is a picture of it!
This is what i have to work with. Cant really figure out what kind of light switch that fit?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: May 13, 2013, 05:43:59 AM »
Isn't the brake light switch on the lower triple tree?
« Reply #5 on: May 13, 2013, 05:46:21 AM »
Ooh ok! So its an hydraulic one on the original? Then ill just buy one of those! On my 81 i have an electronic switch, i was looking for something like that :)
Offline Toxic
« Reply #6 on: May 13, 2013, 09:50:43 AM »
partsnmore sell an aftermarket M/C that has the switch built into it  $69 or so
Offline mronegear
  • Honda CB 550 F 1976
« Reply #7 on: May 13, 2013, 10:13:25 AM »
yes, you got it!
http://www.cmsnl.com/honda-cb550f1-super-sport-550-four-1976-canada_model17110/partslist/F05.html#results
Number 2 in the graphic is the breaklight switch.
cheers!
  • 1977 CB550F2
Offline Stilltime
  • Building my Dream
« Reply #9 on: May 13, 2013, 10:25:26 AM »
I have the tree (from a 550), as well as a banjo brake switch from Sligshot Cycles if you're interested in either.
Switched to a Nissin lever with electronic switch...
'78 CB550 - Orange Crush
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #10 on: May 13, 2013, 10:43:01 AM »
Switch is on the front knuckle as seen in the above link.
What you have taken a picture of is a stop/return post thats missing. It guides the brake lever from over extending as far as I can tell. Some of the old timers will step in and correct this i'm sure. :p
http://www.cmsnl.com/honda-cb500-500-four-k1-usa_model460/partslist/F++04.html#results
You see here there is a plate, post and nut you are missing from there.
#20
#12
#11
(#22,14,13 in the first link in above posts)
« Last Edit: May 13, 2013, 11:03:31 AM by nIkbot »
'73 CB500 upgrades a'comin
« Reply #11 on: May 13, 2013, 01:54:59 PM »
Thanks for all the great help! I just ordered a banjo bolt with a switch in it. It will fit right up by the master cylinder so i can run the rest of the setup from the 81ยด.
Best regards!
Johan
