Author Topic: Frame conundrum  (Read 1208 times)
Offline 78whiteorbs
Frame conundrum
« on: May 12, 2013, 11:15:51 AM »
I got a near complete 1978 Cb750K for a hundred bux yesterday!
It does not have a title and had no rear shocks but turns over and starts easy with great compression. Was missing tank and the seat but for a hundred bux , I figured there was no way I could go wrong.
Wanna make a "bratish" style bike like this one here somewhat minus the Firestones and maybe a super bike bar instead of the clip ons. Anyhow about the frame. Anyone know if a 74cb750K frame would line up in the neck area well with the 78K . I have a titled frame for a 74 and am thinking to just cut the neck off and have a bud of mine who is a pro do the transplant. I was thinking that would be easier than swapping everything else over the the other frame. What do you guys think>?
Offline 78whiteorbs
Re: Frame conundrum
« Reply #1 on: May 12, 2013, 11:56:51 AM »
also does anyone know if a 78 frontend will slide into that 74 neck.
Re: Frame conundrum
« Reply #2 on: May 12, 2013, 03:36:40 PM »
You think cutting and resetting a steering head would be easier, ?  I would have to disagree, just swap frames, far easier.  ;)
Offline lucky
Re: Frame conundrum
« Reply #3 on: May 12, 2013, 04:08:39 PM »
I agree.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
Re: Frame conundrum
« Reply #4 on: May 12, 2013, 05:15:06 PM »
Law of unintended consequences will prevail.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline Vinhead1957
Re: Frame conundrum
« Reply #5 on: May 12, 2013, 06:21:48 PM »
I have never heard Murphy's law called that!
Offline Old Scrambler
Re: Frame conundrum
« Reply #6 on: May 12, 2013, 06:45:41 PM »
Much easier & legal to switch the frame.......but retain the K8 swingarm / chainguard to be sure the sprockets and chain have room.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline 78whiteorbs
Re: Frame conundrum
« Reply #7 on: May 12, 2013, 07:11:06 PM »
good food for thought thanks.
Re: Frame conundrum
« Reply #8 on: May 12, 2013, 08:20:40 PM »
To cut and weld and line up properly you would have to take them both apart anyway. No brainer, switch frames. I have cut and welded on them, lots of work and don't burn that paint, it will make you sick.
Offline RSchaefer
Re: Frame conundrum
« Reply #9 on: May 13, 2013, 07:57:31 AM »
Was always wondering about this lack of title issue?  Seems some states require a title otherwise your frame is toast.  In AZ I'm to understand you can take it to the MVD, post a bond and eventually get a title.  Why couldn't someone take the bike to a state that allows this, get the title, then transfer the titled bike back to their state?  I realize that's allot of time and some money but seems it would be allot cheaper then swapping engines, cutting frames, etc.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline davidtime
Re: Frame conundrum
« Reply #10 on: May 13, 2013, 08:23:24 AM »
Well I have a 550k and I was thinking about doing the same thing with my frame and let me tell you I am glad I didn't because it was a breeze tearing down to the frame.
I undid the electrical up to the front end, removed the whole front end with one clean pull including electrical. That saved a ton of time. I would say I worked on it 4 hours and it was stripped bare.
One reason I went this route is so everything can be cleaned and painted if need be. In the end I will be much happier.
Offline lucky
Re: Frame conundrum
« Reply #11 on: May 13, 2013, 11:37:37 AM »
Have you ever been stopped and have a cop ask to see the frame number or engine #?
Offline RSchaefer
Re: Frame conundrum
« Reply #12 on: May 13, 2013, 12:44:03 PM »
No!  Have you?
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline mono
  • Definitely no
Re: Frame conundrum
« Reply #13 on: May 13, 2013, 01:46:17 PM »
right ?!  i'm in a similar predicament, only i have a titled frame but the head has been attached to another [unknown] year/model, so i have frankenframe.  the welding job looks spectacular, but i don't want to run into a bunch of oddball fitment issues.  considering switching VIN plates to my unmodded, untitled frame and just redoing the stamped in VIN myself.    :P
Re: Frame conundrum
« Reply #14 on: May 13, 2013, 02:56:45 PM »
No!  Have you?
Yes i have, is it worth the risk should be the question....
