Author Topic: Ticking valves after valve cover removal and adjustment  (Read 1272 times)
Offline drj434343
« on: May 12, 2013, 01:15:22 PM »
So my maintenance saga continues on the 71' CB500.  After removing the valve cover and confirming my chain tensioner worked, I reinstalled the cover and adjusted the valve clearances.  3 of 8 were too tight, almost no clearance, the rest were OK.  Got all the intakes to 0.002", 0.003" for the exhaust.
Engine starts and runs great, but I've got a valve click I didn't hear before the removal.  It appears to come from the cyl 4 valves and is loud enough to hear while siting on the bike, although it kind of fades in and out while it runs.  I can hear clicking valves on the cyl 1 side but I have to put my ear pretty close to the engine to notice it.
I've rechecked the clearances and they still look good.  I have a history of doing these adjustments on car engines, and the valve clicks on an old Volvo engine are loud enough to hear in the car.   However, this noise here is new and has me wondering.  Definitely louder on one side than before.
Anything I should consider here?  How loud is too loud?
1971 CB500 K0
1974 CT90 K5
Offline Vinhead1957
Re: Ticking valves after valve cover removal and adjustment
« Reply #1 on: May 12, 2013, 04:55:19 PM »
Absolutely sure of the T position when adjusting?  Double check and make sure the valve is totally closed.
Offline drj434343
« Reply #2 on: May 12, 2013, 06:24:20 PM »
The marks go by in this order as I crank with the kickstarter:
1.  The twin full advance marks
2.  The F mark
3.  The T mark
I've been aligning the T mark.  When I got there, the "closed" valves had enough play that I could wiggle them a bit, so I felt they were fully closed.  If there's pressure on the rockers at all, they're totally immobile.
This started when I removed and reinstalled the valve cover, but I can't think of anything that I would have done to make this happen.
1971 CB500 K0
1974 CT90 K5
Offline lucky
« Reply #3 on: May 12, 2013, 06:31:28 PM »
You can do a quick check like this:
For the intake valves try inserting a .003 thickness gauge. If it slips in that is your loose valve.
For the exhausts try a .004 thickness gauge if it slips in then that valve is loose.
You should always use this method.
Also: A loose ticking valve will cause no damage, but a quiet tight exhaust valve will burn up and crack.
Also if any valves re too tight it can actually keep the engine from idling correctly or at all.
« Last Edit: May 13, 2013, 09:08:22 AM by lucky »
Offline Old Scrambler
« Reply #4 on: May 12, 2013, 06:40:53 PM »
Did you replace the cover gasket and the adjuster-cap gaskets?  If not, check the inspection cap on the loud value to see if the valve is hitting it. I had that happen on my 750 so I installed a new gasket over the old unit on one cap to solve the problem.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline drj434343
« Reply #5 on: May 13, 2013, 07:45:36 AM »
That's an interesting thought.  I went back out and ran it while slowly loosening each cap to see if the tapping went away, but none of them seemed to affect that.  Perhaps there's rocker contact on the main cover.  The cap o-rings and cover o-ring were all pretty flattened, probably original, so I can imagine that when I re-tightened, everything settled even lower than before.  I've ordered a whole new set to lift everything back up a bit.
My clearance checks do involve one size larger fit check, so I'm pretty confident I've got those right.
Perhaps I'm just being too sensitive to the normal valve train signature that is now apparent after loosening too valves that were way too tight.  Would it be normal to be able to detect slight valve ticking sitting on the bike at idle without a helmet?
1971 CB500 K0
1974 CT90 K5
Offline lucky
« Reply #6 on: May 13, 2013, 09:10:00 AM »
These engines from 40 years ago do make some noise, unlike a modern car engine.
Offline Schnell
« Reply #7 on: May 13, 2013, 09:52:04 AM »
Properly adjusted valves on my old airhead sound like a coffee clutch of rabid squirrels knitting furiously.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
