No big updates to report.
I got the motogadget parts i ordered.
Chrono Classic 10k RPM meter with digital speedo.
Transistorized fuse box with the "M Button" addon, wich creates a bus for all wires from the handlebar mounted switches.
I also got the RFID ignition lock.
I have made a test bracket, so i can see how the meter looks when mounted on the bike.
I have mounted a front fender. This alerted me to some problems with clearance on the front fork.
I was under the assumption that the fork had 100mm of travel, but as i have found out. it has 120mm of travel.
With the 19" wheel and the long neck of the Honda, i only have 115 mm of clearance with the fork extended all the way. The fork legs are almost flush at the top triple tree. so i might have to create a custom top triple to get me some clearance for the wheel. Its either that or getting a lower profile tire for the front.
Frode
