Author Topic: 76 Supersport  (Read 20002 times)
Offline frodef2
76 Supersport
« Reply #75 on: June 01, 2015, 12:58:10 PM »
Today i re checked my cam timing.
Initially i made the adjustments with an homemade degreewheel. And i wanted to recheck it when my APE wheel arrived.
It was good that i did the recheck. I had managed to missread the valve closing value by 5 degrees.
The brass adapter i made for my cd-rom degree wheel also fit the APE wheel.
The next thing i did was to modify a Moto GPwerks  swingarm to make it fit my f1. When i bought the thing off evbay i only read cb750f. I was so happy to find a swingarm i did not see that it was for a DOHC.
So today i pulled the needle bearings. Cut off 3mm on each side, and made 2 bronze bushings to fit the SOHC axle. Then i filed the last 1 mm off each side to make sure it was straight.
The damper angle is less than ideal. But i will have to live with it.
Frode j
« Last Edit: June 01, 2015, 12:59:57 PM by FrodeF2 »
76' Supersport
Re: 76 Supersport
« Reply #76 on: June 01, 2015, 02:05:13 PM »
Nice work adapting (milling) the DOHC swingarm to fit.  I love this build.  The motor is going to make some power.
Offline Badluckhonda
Re: 76 Supersport
« Reply #77 on: June 01, 2015, 07:39:37 PM »
How much longer is that swingarm ? Looks awesome
Offline greenjeans
  • 1972 CB750K2
Re: 76 Supersport
« Reply #78 on: June 02, 2015, 08:21:09 AM »
Lots of things to love on this one.   Super nice motor & parts upgrades.   Of all the modern fork upgrades we see here, this is among the first that I can remember that uses 18" & 19" wheels.   To me, those sizes look the best and certainly most appropriate & timeless.   I feel the need to mention the shortened seat pan again - love it.  Have you figured out what to do with the offset of your triples yet ?   Devin at CognitoMoto can make triples with the stock offset - he's a member here.   I also have one of those MotoGP swingarms & exhausts on my 750.  He makes some nice stuff and that swing arm made a noticeable difference on mine.  Stiff might not be strong enough.  I am contemplating the M-unit stuff for mine and can't wait to see how you end up wiring things.
Great build.  Keep it going.
Re: 76 Supersport
« Reply #79 on: June 02, 2015, 09:01:49 AM »
+1 on Devin at Cognitomoto. As a recall, you have a Duc front end. You can send Devin your existing triples and he can make you a set with increased offset (restore it to stock geometry).  I just got my custom trees for my CBR600RR front end and they look amazing.
Offline frodef2
Re: 76 Supersport
« Reply #80 on: June 02, 2015, 09:08:10 AM »
It is actually not the offset that is the problem, its that i am using a 19" wheel. Under heavy braking, the wheel would hit the bottom triple. I have already managed to almost bottom them outwhen they where mounted on my Ducati.  The springs in this fork is made for 5'2" italians barely pushing 120" pounds. And the bike they came from has a dry Weight of 179kg.
I will have to use either a 17" wheel or get longer fork legs.
76' Supersport
Re: 76 Supersport
« Reply #81 on: June 02, 2015, 12:17:17 PM »
The smaller offset may still cause issues with reduced trail.  Retro Rocket can chime in, but you should look at how the modern front end affects the bike's steering and stability.  You can also just step down to an 18" front and respring your fork as necessary.
I am really looking forward to seeing this bike come together.  The JMR engine and all of the trick bits has me hooked.
Re: 76 Supersport
« Reply #82 on: June 02, 2015, 12:40:23 PM »
Smaller offset = more trail
Re: 76 Supersport
« Reply #83 on: June 02, 2015, 02:22:40 PM »
What kind of rotor is that you have on the engine ?
It is from a Yamaha R6. It works great as there are a few of us in New England that have been running them.
Re: 76 Supersport
« Reply #84 on: June 02, 2015, 02:26:34 PM »
Mike,
Are you referring to the Anders set up?
Don
Re: 76 Supersport
« Reply #85 on: June 02, 2015, 02:38:09 PM »
Mike,
Don
Yes Don
Re: 76 Supersport
« Reply #86 on: June 02, 2015, 02:58:18 PM »
Time for some "stupid" questions.  Please indulge me.  Since the Anders / R6 rotor is lighter, I would imagine that there is less flywheel effect.
Does this system rev faster AND higher?
How fast can you rev the motor (what does this increase the redline to)?
Do you lose any torque in the rev range?
Re: 76 Supersport
« Reply #87 on: June 02, 2015, 04:28:35 PM »
Correct... ;)
Re: 76 Supersport
« Reply #88 on: June 02, 2015, 04:30:11 PM »
Correct... ;)
Yep.  I had a polarity shift for a second.
Re: 76 Supersport
« Reply #89 on: June 02, 2015, 06:15:04 PM »
I think with the offset your getting from that cbr1000 front end I would definitely go 18in wheel or 17. That 19 and current offset is gonna give you a slow responding front end
Re: 76 Supersport
« Reply #90 on: June 02, 2015, 06:17:12 PM »
Do use the stock keyway ? And can you run no battery ?
Re: 76 Supersport
« Reply #91 on: June 02, 2015, 06:18:07 PM »
Springs suiting the new weight the front end has to cope with would help as well.... ;)
Re: 76 Supersport
« Reply #92 on: June 04, 2015, 04:32:32 AM »
It will rev quicker secondary to less weight. It will not allow for more "safe"revs but it has to be easier on the crank snout because of the lighter weight. Much better starter gear engagemnet. Torque is good though my engine is 1000cc
Re: 76 Supersport
« Reply #93 on: June 04, 2015, 04:37:02 AM »
No keyway...Anders supplies an adaptor for a friction fit on the crank snout (just like stock). I would think you need a power source to start the bike ( even kick starting) so you would need some type of battery (it is not like a magneto)
Offline frodef2
Re: 76 Supersport
« Reply #94 on: June 14, 2015, 03:44:08 AM »
This last week i sourced a new rear axle bolt for the dohc swingarm. I also made a spacer to make the rear wheel fit snugly between the arms. It looks like i have gotten the wrong bolt, as it is too short.
I guess i have gotten a bolt for a drum brake DOHC.
76' Supersport
Offline frodef2
Re: 76 Supersport
« Reply #95 on: August 12, 2015, 01:42:05 PM »
No new updates with the CB this time, as i have hardly done anything to it this summer.
I have received new carbs and boots from my American connection.
I did get a few small side project this summer. A 1965 Vespa 50S and trying to learn how to do metal shaping.
Me and my dad are almost finished with the left fender of the 1931 pontiac seen in the two first piuctures. My dad does the welding , and i grind the welds and hammer the fender back in to shape.
This is the state of the "bike" when i bought it.
The moped had been off the road since the early 70's, and had hardly any rust.
the previous owner dismantled it to try to restore it but lost his confidence.
3 weeks later it looks like this:
A few days later i rolled on the aluminium legshield beading. luckily i bought 2 beadings, as i destroyed the first one.
Today i put on the runningboard protectors and the vespa badge.
Of the 8 old rivet holes, only 2 fit the new badge: Italian "craftmansship".
This is the finished frontend.
76' Supersport
Re: 76 Supersport
« Reply #96 on: August 12, 2015, 02:58:55 PM »
I was going to call in a Smurf scooter until I saw the last pictures with the trim.  Very nice little scoot.
Offline MessnerMoto
Re: 76 Supersport
« Reply #97 on: August 14, 2015, 12:56:32 PM »
Lovely build :) Just found it
