Author Topic: Throttle cable end will not fit into new right hand switch.  (Read 552 times)
Offline D-Ral
I ordered a new pull throttle cable and right hand switch from www.vintagecb750.com. The cable end will not fit into the switch. It looks like if I file the sides of the ends down a bit it will fit, but I just wanted to see if anyone else has had this issue. The site didn't have a push cable in stock, so I ordered a motion pro and it fits fine. Also, I ordered a supposedly oem style throttle tube/sleeve from the same site, and it won't fit into the switch either! The switch is identical to the oem, I have a broken one to compare. Weird...
Offline mronegear
  • Honda CB 550 F 1976
Re: Throttle cable end will not fit into new right hand switch.
« Reply #1 on: May 16, 2013, 12:35:41 AM »
Sorry, don't know, but that's why i always go for nos parts if still available.
good luck!
Offline D-Ral
« Reply #2 on: June 13, 2013, 06:20:21 AM »
I filed the end down a bit and it slipped in no problem.
Offline toytuff
  • "watching the pinheads"
« Reply #3 on: June 13, 2013, 06:34:09 AM »
Had the same problem with their throttle sleeve on the 750.
Sent it back.
tt
Offline D-Ral
« Reply #4 on: June 16, 2013, 05:14:33 AM »
Ok, I'm glad it wasn't just me. I just noticed that the right hand switch is made to allow the wires to be run outside of the bars, which is convenient. But the jury on the switch until I get everything it switches to work.
