Had the carbs off the bike again today, tried the 'light behind the slide' and 'guitar string' method of bench syncing... cleaned everything out again (although it was totally clean anyways) and put it all back together. I noticed that the slides don't quite come right to the floor of the intake, even with the screws all the way up... on all 4 carbs there is a very very small bit of light that gets through to the other side. Is this normal, or are my slides screwed up?
The bike immediately idled at 1200RPM - EUREKA!... not. After a few minutes I revved the bike up to around 5k, it never did come back to 1200... it bounced around 3k the entire time. It's also spitting a bit of fuel out of the carb intake on the #4 and maybe the #2.
Took it out for a ride, sometimes it idles at 2k, sometimes is just dies. Other times is fluctuates back and forth between 2500 and 3200 RPM.
The gas is good and clean, and so is the tank. I've tried looking for vacuum leaks multiple times with starter fluid. The ignition is working fine. I have no idea what the I should be doing at this point... The stuff to build a manometer is in the mail... however by reading on here... the bike should at least half-assed idle without a vac sync. I'm trying everything I can figure out how to do to this thing and none of it seems to be working. Help!
