Author Topic: Separating forks on CB125  (Read 909 times)
Offline Untold
« on: May 19, 2013, 02:01:06 PM »
Trying to change the fork seals on my 1975 CB125S. I assume the forks are stock, but I'm not sure. They have dust caps, not fork boots. I removed the screw on the bottom of the fork leg, but the inner tube won't slide out through the seal.  I'm assuming it's the type that requires the slide-hammer technique to pop the seal out but mine are not budging at all. THey've been soaking for 2 days in PB Blaster, and still no movement.  Any tricks to getting these forks apart?
Thanks
1976 CB550K
Offline Old Scrambler
Re: Separating forks on CB125
« Reply #1 on: May 19, 2013, 03:20:29 PM »
I have pulled CB100 and CT90 forks apart and I think you have a snap-ring washer to remove and then 'hook' the seal and pull it out.  A properly sized driver or piece of pipe helps to install but little effort is needed.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Untold
« Reply #2 on: May 19, 2013, 04:00:44 PM »
I got it. I had the snap ring out already. It was just a matter of breaking the seal loose. Some PB Blaster and the heat gun loosed it up enough for the slide-hammer technique. I've also determined that I have 1978 forks on this bike, so the seals I have are the wrong size. Now to figure out the fork oil capacity.
1976 CB550K
