My project has been done for some time now and I am really pleased with the results. Most of all it is so gratifying to rescue a once-lovely bike that was badly rusted, seized and neglected for 30+ years.
The goal was to get it to decent looking original running condition and I am pleased to say that except for the MAC exhaust the bike is 100% original and complete down to the smallest parts. Like the air filter spring that I had to get from the UK and the air filter cover that I managed to get manufactured. OEM Honda parts used for the majority of the restoration where possible, down to nuts & bolts. I've already done over 1100 miles on it and it runs like a dream!!
A big Thank You to everyone on the site whose comments & suggestions, both past & present, were a huge help throughout the process. Here is a list of all the work I did and a few pics.
Frame & Tank
• Touch up frame and swingarm
• Paint battery tray
• Clean and reassemble steering head
• De-rust tank & replace tank cap seal
• New strainer set
• Replace tank chrome trim
• Replace seat lock rubber bushes
• New keys
• New mirrors
• New MAC exhaust
Brakes
• Rebuild & paint front caliper
• New piston
• Rebuild master cylinder
• Unfreeze and service rear brake
Suspension & Tires
• Polish fork legs
• Replace fork seals & fresh oil
• Dismantle and derust rear shocks
• New Bridgestone Battlax tires
Electrical
• Repair ignition switch
• Replace & repair starter button
• Adjust voltage regulator to spec
Engine
• Free up stuck pistons
• Soda blast & paint engine
• New piston rings & gudgeon pins
• Hone bores & Lap valves
• Top end gasket set
• Rocker arm shafts O-ring “fix”
• Unfreeze and clean up clutch
• Polish all side covers
• New points cover
• New air filter, retaining spring & triangle cover
• Obtain used tool tray
• New tool kit
Carbs
• Soda blast & rebuild carbs
• New carb/filter rubber boots
• Replace linkage alignment springs
• Replace main jet holder springs
