Author Topic: Steering head bearings: this is a lot of work  (Read 2692 times)
Offline Schnell
« on: May 20, 2013, 06:36:49 AM »
Just thinking through the logistics in anticipation of this job.
Disconnect speedo cable, remove front wheel, fender, and disconnect brake line, THEN there's all the electrical cables between the chassis and the controls on the bars, headlight and gauges. Snap!
I guess the handle bar could be disconnected from the triple tree, and left draped across the tank? What about the gauges and headlight?
Could someone who's done this share any tips to reduce unnecessary steps/work, please?
« Last Edit: May 20, 2013, 06:42:07 AM by Schnell »
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline Tews19
  • I am no
Re: Steering head bearings: this is a lot of work
« Reply #1 on: May 20, 2013, 06:55:10 AM »
Its really simple actually. I do this to all my bikes. Do you have internal wiring for the hand controls?  If so not a big deal.
Put bike on center stand. Or on lift. Remove tire. The brake on the lower triple. You can leave the wires in the handle bars just in the bucket.
Make sure before its lifted that you loosen up the 14mm bolts on the lower triple. Remove the fork tubes. Loosen the center cap and the stem should come out.
A little more goes into it but its real easy.
1970 Honda CB750 survivor.
« Reply #2 on: May 20, 2013, 06:55:23 AM »
I left the brake caliper on - just tied it with a piece of wire.
The handlebars same thing - I tied them to the celing somehow to make sure no wires get torn off or pulled out.  It feels much trickier than it really is.
Offline DJ_AX
« Reply #3 on: May 20, 2013, 07:42:04 AM »
yep ... Like everything I've done so far on these bikes.... the anticipation is often more energy consuming than actually doing it. lol
Offline Schnell
« Reply #4 on: May 20, 2013, 08:38:44 AM »
The second time doing something is more than twice as easy as the first time, having had the experience. This is my first time doing this.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #5 on: May 20, 2013, 08:59:47 AM »
Try tying the handlebars and instruments with top tree  all together from up  above as suggested. But. Remove tank to be safe..if you change to tapered rollers, the fork/lower tree will be way easier to remove after that..
Offline KennyRedman
  • 1976 CB550F, Indiana
« Reply #6 on: May 20, 2013, 10:43:05 AM »
So true!
Offline gto_ron
« Reply #7 on: May 20, 2013, 02:52:49 PM »
I'm also anticipating replacing my steering head bearings. I have the AllBalls kit.  What other parts will I need?  Should  I replace other seals?
Thanks for any responses
76 CB750K
72 CB350F
64 GTO
why yes, I am old-school, so what?
These are the good old days.
Offline bjbuchanan
« Reply #8 on: May 20, 2013, 03:14:23 PM »
While doing the bare minimum for the job you won't run in to any other seals to replace for the hell of it
Fork seals leak when its time to rehab so it has a tell tale sign. If the caliper isn't locked up or weeping then no caliper seal either. Pretty much it for the "localized" area
« Reply #9 on: May 20, 2013, 03:29:36 PM »
Remember to put the fat washer under the bearing race before you press it on :) - and dont ask me why I stress this point :)
Offline bjbuchanan
« Reply #10 on: May 20, 2013, 03:32:29 PM »
Really good point
Offline Schnell
« Reply #11 on: May 20, 2013, 06:40:12 PM »
Are you referring to the top or bottom (or both) bearings?
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #12 on: May 21, 2013, 03:37:21 AM »
The bottom bearing, the one right above the steel bracket.  Once you get the bearing on it, it will not come off easily.
Offline Schnell
« Reply #13 on: May 21, 2013, 04:43:25 AM »
Okay, thanks for the tip!
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #14 on: May 21, 2013, 06:39:11 AM »
You mean ifyou are running tapered roller  version, correct?))
« Reply #15 on: May 21, 2013, 06:46:25 AM »
Yes.
« Reply #16 on: May 21, 2013, 06:46:33 AM »
In this middle of doing this myself....All Balls Kit
Of course then I thought Id change the torn fork gaiters and change the leaking for seals....and the gauge lights need replacing - then I found out the gauge wiring needed replacing....
Good luck!
Andy
Offline RSchaefer
« Reply #17 on: May 21, 2013, 06:52:43 AM »
I'm thinking there is also a rubber grease seal 1st, then the big washer and then the bearing?  I'm thinking the rubber seal is to help hold in the grease on the bottom bearing?
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline Schnell
« Reply #18 on: May 21, 2013, 07:26:57 AM »
Those pictures are very helpful, thanks! You've got everything disconnected and unplugged. I was hoping to minimize that collateral work.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
