Author Topic: 16 x 4 on sohc rear hub  (Read 1784 times)
Offline thelowmax
« on: May 21, 2013, 08:13:12 AM »
I'm building a rear tire with an SOHC hub and a 16 x 4 drop center rim to accommodate a 140 tire. I am currently polishing all the pieces before I start assembling and have come across a question I can't seem to find the answer to. It's always the simple ones that baffle me. What's the deal with the valve? Will a standard inner tube's valve fit into the rim's opening or do i have to buy a separate valve?
What are all the basic components of the wheel? Rim, spokes hub, tire, inner tube, liner strip...Am I forgetting anything?
What am I doing and why am I doing it? Those are excellent questions.
'72 Amen Savior/'77 CB750K Chrome/Da Bhudda(project)
'73 CB750K Green/El Verde (beat)
'76 CB750K Red/The Cinnabomb (sweet)
'77 CB750K Black (frame and parts) CANNIBALIZED
'77 CB750K Dark Purpley/Scooty Puff, Jr. (la beast)
'78 CB750K Black (struggling) SOLD
'78 CB750K Blue Flake/CiocioSan (minty)
'81 CB750C Poiple/Barbie'sDreamMotorcycle SOLD (darnit!)
'89 Trek 21" 21 speed Green/YaBiatch (the wife)
Converse One Stars size 8.5 Black/Sneaks (suede)
Offline Vinhead1957
Re: 16 x 4 on sohc rear hub
« Reply #1 on: May 21, 2013, 09:09:04 AM »
Bearings
Offline Xnavylfr
« Reply #2 on: May 21, 2013, 09:11:42 AM »
NIPPLES!!!!
for the spokes
Xnavylfr(CHUCK)
Offline thelowmax
« Reply #3 on: May 21, 2013, 09:39:16 AM »
Nipples. New bearings in.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: May 21, 2013, 10:22:52 AM »
Is the hole for the valve offset to one side of the rim? If so you will need an inner tube to match.
Offline Vinhead1957
« Reply #5 on: May 21, 2013, 10:23:26 AM »
They come with the spokes and males for some unknown reason!
Offline thelowmax
« Reply #7 on: June 02, 2013, 09:30:47 AM »
Tube with offset valve. Now that makes sense. Thanks guys.
bollingball
« Reply #8 on: June 02, 2013, 10:06:09 AM »
Also there are off set valves that go straight or at a 45. Some times it is a little difficult to get a gauge on a straight one.
Ken
« Reply #9 on: June 02, 2013, 10:52:26 AM »
Sprocket?
Offline thelowmax
« Reply #10 on: September 20, 2013, 06:55:44 PM »
Don't forget to buy some new brake shoes. I did. :(
Just ordered some.
Offline derelicte
  • '74 CB750
« Reply #11 on: September 21, 2013, 07:10:48 AM »
Don't forget to line up the circle inked on the tire with the valve when you install the tire.  Its the lightest part to help when you balance, ask me how I know :/
Offline thelowmax
« Reply #12 on: September 21, 2013, 08:30:05 AM »
One thing I always leave to the professionals is changing tires. For $20 a tire, it's just cheaper and easier. I know I'ld gouge the hell out of them and it would take me hours.  Lesson #1, Grasshopper. Know yourself.  ;)
