Author Topic: Wiring Harness Connectors  (Read 810 times)
Offline ncstatecamp
« on: May 24, 2013, 04:57:53 PM »
I have my wiring all sorted out now I just need to clean everything up and put more permanent connections. What are the connectors call that are 2, 4, 6, 8 bullets called and where (USA) can I get them local? Im talking about the connectors that join either 2 parts of a harness together or from an after market taillight to the rest of the harness. Thanks ahead of time
Offline wowbagger
  • Not much of an
Re: Wiring Harness Connectors
« Reply #1 on: May 24, 2013, 05:09:13 PM »
Check out this site: http://www.vintageconnections.com/
They should have what you're looking for.
Offline mono
  • Definitely no
« Reply #2 on: May 24, 2013, 06:43:48 PM »
Yeah I'd order them online.  I looked all over for a local source where I live, and no major or small retailers had them.  They're an obsolete connector I think.
Sent from my SPH-L710 using Tapatalk 2
Offline ncstatecamp
« Reply #3 on: May 24, 2013, 06:44:48 PM »
What do they use now then?
Offline Vinhead1957
« Reply #4 on: May 24, 2013, 06:56:26 PM »
I got them there! Get the crimper too
Offline vma03
« Reply #5 on: May 25, 2013, 12:20:31 AM »
Getting ready to rebuild my 550. The original wiring seems to be working okay, but I'm still thinking about redoing the wiring for reliability. So I get that the bullet connector is correct for originality, but what would you use for more "modern" electronic connectors?
Offline ncstatecamp
« Reply #6 on: May 25, 2013, 02:13:00 AM »
what about these? for the price/pkg quantity seems the best deal
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #7 on: May 25, 2013, 05:09:52 AM »
+1
Definitely get the crimper or try to borrow one.  It makes an absolute world of difference when attaching the connectors.  If you are doing any custom work I would buy more than you need.  I wasted a few connectors on my build.
« Reply #8 on: May 25, 2013, 08:49:27 AM »
If you want to convert to modern connectors you can get GM weather pak connectors. They are slightly expensive but a lot of racers use them. Generic kits are available.
Offline CapeCafe
« Reply #9 on: May 25, 2013, 09:26:57 AM »
I just finished a complete 550 harness rebuild and used the guys below for all my connectors. You can get twice what you need in the $4.95 flat rate P1 box.  I'd recommend getting extras.  They shipped same day as order USPS P1.
      http://www.newmotorcycleparts.com/electrical/connectors.html
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
1995 Ducati 900 SS/SP
2000 Ducati 900i.e.
Offline ncstatecamp
« Reply #10 on: May 25, 2013, 12:51:04 PM »
I meant to post these in my last post http://www.mcmaster.com/#signal/power-connectors/=mwfklj
