Author Topic: Rear Master Cylinder....I give up !  (Read 1259 times)
Offline MOONDOGNYC
  • BLOOD, SWEAT AND GEARS
« on: May 25, 2013, 11:23:19 AM »
So I bought a rebuild kit for my 77 CB750f SuperSport.   The problem is that the circlip is rusted in place and in peices. It looks like someone may have tried to gouge it out too,as the top of the bore appears scratched.
 So I give up....I can't get it out....Now what ??  Please help.
« Last Edit: May 25, 2013, 11:26:53 AM by MOONDOGNYC »
1977 CB750F
Offline Johnie
Re: Rear Naster Cylinder....I give up !
« Reply #1 on: May 25, 2013, 11:27:38 AM »
Had the same issue. Used some rust disolving spray...PB Blaster and let it work. Then used mechanics picks to finally get it out. One tab of the circlip had broke off too.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline MOONDOGNYC
Re: Rear Master Cylinder....I give up !
« Reply #2 on: May 25, 2013, 11:38:24 AM »
SHould have mentioned that I did that too...   losing my mind with this little $%#@# part....
1977 CB750F
Offline nevernoluck
  • Nope I don't have a clue
« Reply #3 on: May 25, 2013, 11:56:22 AM »
Kroil works good for soaking what pb blaster doesn't do good enough at. Other than that without seeing what you are dealing with and not having done that exact part before but using my past experience, picks or sacrifice a small straight screwdriver and either grind it down or bend it to suit your needs might help too as they tend to be a little tougher. Show me a pic and I might have other ideas too.
Offline skidooextreme
« Reply #4 on: May 25, 2013, 12:03:25 PM »
From my cb750c.com site
Credit goes to Tourmaster
Here's an interesting bit of information that's being passed around our vintage motorcycle group here in Saskatchewan. This may have come up before, but if not, makes for an interesting alternative to breaking free those nasty seized up components ..........
Machinist's Workshop magazine tested penetrants for break out torque on rusted nuts with significant results!
They arranged a subjective test of all the popular penetrants with the
control being the torque required to remove the nut from a
"scientifically rusted" environment (obviously a BIG nut!).
Penetrating oil ...... Average torque
None ....................... 516 ft lbs
WD-40 ................... 238 ft lbs
PB Blaster .............. 214 ft lbs
Liquid Wrench ..... 127 ft lbs
Kano Kroil ............. 106 ft lbs
ATF-Acetone mix....53 ft lbs
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
transmission fluid and acetone. Note the "home brew" was better than any
commercial product in this one particular test. Our local machinistgroup mixed up a batch and we all now use it with equally good results.
I have also heard of people putting sea foam in seized engines and it working in a few hours.....try that in there
Offline nevernoluck
« Reply #5 on: May 25, 2013, 12:12:48 PM »
Glad to see kroil not too bad from lab testing compared to the rest, just knew it worked for me but that home brew sure looks good and cheaper.
Offline MOONDOGNYC
« Reply #6 on: May 25, 2013, 12:59:53 PM »
Giving it a try....let you guysknowthe outcome. Thanks !
1977 CB750F
Offline phil71
« Reply #7 on: May 25, 2013, 02:55:09 PM »
I have seen those results floating around. They're intriguing, but I can't figure out how they managed the controls for the test. It would seem a huge task to make a bunch of bolts rust the same exact way for a test like this.
Offline dusterdude
« Reply #8 on: May 25, 2013, 04:17:22 PM »
Damn,that makes me want to cry,im a pb man all the way
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline JohnG
  • 1976 CB750F - original owner
« Reply #9 on: May 25, 2013, 05:13:47 PM »
heat might help in addition to the oils mentioned.
Every one I ever worked on broke. Too much moisture near it.
I recall taking a small hammer and thin screwdriver and tapping sideways  (as much as that is possible) which caused the clip to move sideways in the groove a little, which got things going.
Once I used the drill press and a very small bit and drilled a new hole in the remants of the clip, which allowed me to get a pic into it and pry it out.  Dinged up the groove a little in the process but nothing that did not keep the new one from doing its job.
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
Offline xsmooth69x
« Reply #10 on: May 26, 2013, 08:16:25 AM »
blow torch
1975 CB550 (FINISHED?!?!?)
Offline Killer Canary
  • Typical Bran Muffin
« Reply #11 on: May 26, 2013, 10:14:20 AM »
There's a vintage motorcycle group in Saskatchewan?
Kawi GPz900, H1
« Reply #12 on: May 26, 2013, 10:24:23 AM »
I broke off both tabs on one when I first got back into sohc's. I finally drilled a small hole from the back side directly into the groove where the snap ring sits. The bit caught the snap ring and popped it right out. I hadn't planned on it working that well but the M/C's  still in use several years later. This was a front but aprocedure that might work for you, use your own judgement. When you are done, don't overstroke the cyl when bleeding. You can let fluid back into the snap ring area. There was a bulletin about it years ago.
