Author Topic: Fork caps  (Read 688 times)
Offline azuredesign
  • Knupping pin
Fork caps
« on: May 25, 2013, 03:00:22 PM »
I would like to close off what I think are(or were) air nipples in these fork caps that I am using on the GL1000 front end I am putting on my k3. Any suggestions how to do so greatly appreciated!
Thanks
Offline OldSchool_IsCool
  • Really feeling like an
Re: Fork caps
« Reply #1 on: May 25, 2013, 03:03:14 PM »
I'd plug 'em with a shrader valve and a cross-over tube and enjoy the fact that you have a K3 with air forks!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline azuredesign
  • Knupping pin
Re: Fork caps
« Reply #2 on: May 25, 2013, 03:52:30 PM »
Hmm, I am thinking of drilling out the nipples and installing set screws with o rings. I am using Racetech springs and gold valve emulators. I would be surprised if air pressure stays constant in a fork leg. Seems to me it would be like a tire with a slow leak, but I have no personal experience.
Re: Fork caps
« Reply #3 on: May 25, 2013, 08:51:19 PM »
If you must.. Pipe thread..not setscrew...or trade for nice chrome set..
Re: Fork caps
« Reply #4 on: May 25, 2013, 09:43:49 PM »
It takes about 2 weeks for the air to leak down 50% if the fork seals are good. The top air pressure should only be about 7 PSI (10 with 2-up riding). At about 3-4 PSI it stops oil weeps from the [good] fork seals quite well!
