Author Topic: Maintenance fuel tank  (Read 924 times)
rotortiller
« on: May 26, 2013, 06:46:22 AM »
I was about to toss a motorcycle battery electrolyte container and then thought better and used it for a small fuel tank. Works good for balancing the carbs. I drilled a hole in the top and installed a small vent fitting and used the existing fill nipple with fuel tubing and a filter. It should go without saying the container needs to be flushed clean. If it survives battery acid gasoline should be fine.
Re: Maintenance fuel tank
« Reply #1 on: May 26, 2013, 06:50:01 AM »
Recycle-Reuse--Looks like it should work fine. Somekind of a little bracket to hang it and your golden. On mine from a lawn mower I bought a cheap inline petcock for a few buck that I can turn the gas off when I,m done and a splitter for hooking to more that one nipple.
« Last Edit: May 26, 2013, 06:53:13 AM by ekpent »
« Reply #2 on: May 26, 2013, 07:01:30 AM »
Most hardware stores etc sell these little cheapies that work well.
« Reply #3 on: May 26, 2013, 08:05:23 AM »
Awesome 8)
bollingball
« Reply #4 on: May 26, 2013, 02:52:21 PM »
Wow I use that same bottle to work on them while on the bench stand to fill and check the floats. Don't have the filter guess I should.
Offline Steve_K
« Reply #5 on: May 27, 2013, 05:07:39 AM »
I have a lawn mower tank with a shut off similar to your set up.  I made a hanger with an old large diameter pulley for the floor and a T at the top to hang the tank and my  Motion Pro carb balancer.  Much cheaper than one you can buy.  I like yours!
Steve
Steve_K
