Author Topic: cb550 oil leak at shifter pedal  (Read 1590 times)
Offline joemcvw1951
« on: May 26, 2013, 01:16:24 PM »
I just got this bike running , after a while I noticed a very small oil drip that looks like it's coming from behind the shifter pedal shaft. I suspect a seal but I don't see one on the Honda parts microfiche .
Any ideas ?  I hope it's something I can get to without removing the cover,
Thanks
Offline Mooshie
Re: cb550 oil leak at shifter pedal
« Reply #1 on: May 26, 2013, 01:24:34 PM »
I had the same thing on my 550.  The oil may appear to be dripping from there but it most likely is making a long drip route to finally fall there.  My leak was from the oil pump (there are 3 o rings if I remember correctly) and I just went in and replaced them all.  The other culprit could be the shifter seal but that seemed like a true pain to change and luckily my leak was not from there.  The other culprit could be the drain pan gasket seal.
If you want to trace it take of the oil cover and spray white foot powder (don't get the clear aerosol foot powder-make certain it is white) and after cleaning the area good give it a light spray (it will dry white) then ride your bike around a bit and  the leak will be evident as it will break through the white powder. then go in and change the seal that is leaking.
Hope this helps.  There are lots of how to's on the forum once you locate it.  But look at oil pump, shifter seal, and drain pan
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline joemcvw1951
« Reply #2 on: May 26, 2013, 01:26:04 PM »
thanks, I will try it !
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: May 27, 2013, 12:17:40 AM »
Oil pump, main shaft, shifter shaft. If you're going in you might as well replace all of them.
Oil pump O-ring x2 91301-268-020
Oil pump O-ring X1 91302-250-010
Shifter shaft seal x1 91202-KFL-841
Main output shaft seal x1 91205-283-015
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline matt mattison
« Reply #4 on: May 27, 2013, 02:58:04 AM »
Mine will drip sometimes after I lube the chain. The excess finds its way down the shifter shaft and onto the floor. Usually only a couple drips though.
1975 CB550F
2011 MV Agusta Brutale 1090RR
