Author Topic: CB400f Fork Disassembly, What's The Trick?  (Read 1066 times)
Offline Powderman
« on: May 26, 2013, 01:46:40 PM »
So I am taking the front forks apart to restore with new powder coat and probably vapor blasting instead of polishing the lower legs. I have the spring out and have broken loose the lower allen bolt but it just spins now that it is loose and is independent of the tube. How do I get it out?
Offline Johnie
Re: CB400f Fork Disassembly, What's The Trick?
« Reply #1 on: May 26, 2013, 01:52:58 PM »
You could try putting the spring back in and tightening the top back down and sometimes that works. But many guys take the spring out and use a broomstick cut to size. Then tighten down the nut and it will place pressure on lower so you can get the allen out.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Powderman
« Reply #2 on: May 26, 2013, 02:11:05 PM »
I'll give the broomstick a try. I loosened the lower allen before I took the spring out so that step didn't work.
Thank you.
bollingball
« Reply #3 on: May 26, 2013, 02:15:40 PM »
An allen on a air impact works to it spins it so fast it comes off before the top part can catch up ;)most use the broom stick pvc or put the spring back like Johnie said above. You have it broke loose that is usually the hard part.
Ken
