Author Topic: cb550 clip on handle bars and clutch cable -_-  (Read 3062 times)
Offline xsmooth69x
« on: May 27, 2013, 08:50:22 PM »
does anyone whos running clip on handle bars with there cb550 have any trouble with stock clutch cable?
the one i ordered for the cb550 from pro motion for the 550 just seems long or maybe its the clip ons. i just cant get it tight unless the cable is backed all the way out by the clutch case and backed all the way out at the lever.....
1975 CB550 (FINISHED?!?!?)
Offline shinyribs
Re: cb550 clip on handle bars and clutch cable -_-
« Reply #1 on: May 27, 2013, 09:12:36 PM »
How does your new cable compare to your old cable when laying side by side? Does the new one have more cable hanging out of the sheath?
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline xsmooth69x
« Reply #2 on: May 27, 2013, 09:42:21 PM »
never had the original  :(
Offline shinyribs
« Reply #3 on: May 27, 2013, 10:53:48 PM »
Ah, that's a bummer. Maybe someone with a 550 can measure up the free length of their cable to verify you recieved the right one. Good luck dude.
Offline xsmooth69x
« Reply #4 on: May 27, 2013, 11:05:48 PM »
3 inches from what i understand..... does anyone make like shortened lines or someone with pics on how they routed them or am i just crazy?
Offline matt mattison
« Reply #5 on: May 28, 2013, 02:58:30 AM »
You need shorter cables with clip ons. At least I did. Motion pro makes them, quite common.
1975 CB550F
2011 MV Agusta Brutale 1090RR
Offline shinyribs
« Reply #6 on: May 28, 2013, 09:21:02 PM »
Shorter overall cables may help with the routing of the cable when using clip ons,but the free length should remain the same.
Offline jamesbekman
« Reply #7 on: May 29, 2013, 07:14:46 AM »
Did you lube your motion pro cables?  They are different from the Honda Oem cable and need to be lubed.  Hopefully that solves your issues.
Offline xsmooth69x
« Reply #8 on: May 29, 2013, 09:04:31 PM »
well the routing is fine
the extra slack i have to go measure it but i swear it was like 3-3.5 inches
ow yes i used the official promotion cable lube
MATT- do you have a 550? what model pro motion cable did you use?
« Reply #9 on: May 30, 2013, 02:49:30 AM »
Yes, I have a 1975 CB550. It's going on 2 years since I put my bike backing the road, so recalling the part #'s is kinda hard. I ordered the speedo, tach, clutch and throttle cables from Dime City. If I can dig up the old order, I will post the part #'s for you. The good part about DCC is that they're pretty easy  about returns, so if you order the wrong cable, they will exchange it.
1975 CB550F
Offline xsmooth69x
« Reply #10 on: June 01, 2013, 01:13:53 PM »
+1 thanks. Dont worry about the part # i dont want to inconvenience you ill just take some measurements and do some more reading. there must be something im messing up. i doubt we are the only 2 people running clip ons
Offline LesterPiglet
  • 1977 CB550F2
« Reply #11 on: June 01, 2013, 02:30:57 PM »
I think I have the same problem. The cable I ordered is too long, it must be for US bars as UK are lower.
Offline xsmooth69x
« Reply #12 on: June 01, 2013, 10:51:07 PM »
well i can deal with the length but its the inner line that was to long -_-
