Author Topic: unstoppable oil leak !!! HELP!  (Read 3040 times)
Offline chrometank
  • cb750 1976 owned 33 yrs
« on: May 17, 2005, 04:14:33 AM »
Hey Guys, I have replaced my alternator gasket.It has a nice oil tight seal.I have replaced my transmission gasket,also a nice seal.Inbetween the two diferent gaskets  is a 1cm air gap and that is where my oil literally pours out when it gets hot.Anybody got any experience with this? cheers ??? ??? ???
Offline mcpuffett
Re: unstoppable oil leak !!! HELP!
« Reply #1 on: May 17, 2005, 05:11:09 AM »
sounds like you have something missing  :-\ was it doing this before you changed your gaskets? anyone else have any ideas?  mick.
Offline chrometank
« Reply #2 on: May 17, 2005, 06:00:57 AM »
gday,everything is there.Only changed gaskets.to much oil for seepage.There is a small machined and counter sunk hole about half way up the alternator case closest to back of bike,I didnt think the alternator was supose to fill with oil ,so i suspect this is some sort of breather hole .you can only see it when you take the transmission cover off.I wonder if this is it?
Lumbee
« Reply #3 on: May 17, 2005, 06:08:51 AM »
...unless I'm mistaken, there is oil in/behind the alternator cover.  Not sure how much or if muc pressure is there, but oil does live there...
« Reply #4 on: May 17, 2005, 06:15:25 AM »
The rubber blocks that hold the stator and field coil wires are not sealing. It is common. Remove the transmission cover and clean the area around the blocks and the blocks REALLY WELL with brake cleaner. Get some Hi Temp silicone (red or copper color) and apply it around the blocks, engine case and cover- don't over do it. In the future put some silicone between the blocks and around the perimeter of the blocks before you install a gasket. Also make sure your starter O ring is good.
« Last Edit: May 17, 2005, 06:17:03 AM by MRieck »
Offline chrometank
« Reply #5 on: May 17, 2005, 06:21:00 AM »
great ,thanks for the advice.its 11.20pm in aussie land so ill try it first thing tomorrow when i get to work.cheers
Offline chrometank
« Reply #6 on: May 18, 2005, 03:06:11 AM »
FANTASTIC-the silastic around the wires worked perfectly,thank you
« Reply #7 on: May 18, 2005, 04:42:41 AM »
Your welcome. ;)
Offline jwalters
« Reply #8 on: May 18, 2005, 10:58:20 AM »
Ya, I think MRieck is right on.  I had the same problem, the little rubber piece that feeds the alternator wires through the cover needs to be fitted just right.  I got some non-silicon high temp liquid gasket stuff at orielly's and put some just in that region.  That seemed to clear it up.  (This was also the advise given to me by our local Honda dealer mechanic)
1997 Suzuki Bandit 1200S
1972 Honda CB 750 K2 "Cafe Racer"
