Author Topic: Trim old tube to use for a rim strip?  (Read 3879 times)
Offline DJ_AX
« on: May 30, 2013, 12:17:36 PM »
Can I just trim the old inner tube to use for a rim strip?  ???
Seems like it would be better...  ???
Re: Trim old tube to use for a rim strip?
« Reply #1 on: May 30, 2013, 12:19:50 PM »
I done for motorcycle and for bicycle before. It works.
Offline DJ_AX
« Reply #2 on: May 30, 2013, 12:27:12 PM »
Thanks!
Offline Vinhead1957
« Reply #3 on: May 30, 2013, 12:39:19 PM »
They are cheap enough ?  JB cycles
Offline Untold
« Reply #4 on: May 30, 2013, 12:42:07 PM »
duct tape works, too
1976 CB550K
bollingball
« Reply #5 on: May 30, 2013, 12:44:51 PM »
Two layers of duck tape works just as good. That is all my local Honda shop uses unless you demand different. That is all I ever use. Works fine you still need to file any sharp edges no matter what you use.
Ken
bollingball
« Reply #6 on: May 30, 2013, 12:47:00 PM »
Untold beat me to it while typing :)
Ken
« Reply #7 on: May 30, 2013, 01:54:34 PM »
Duct or electrical for me...
Offline DJ_AX
« Reply #8 on: May 30, 2013, 06:39:40 PM »
It was a loose fit... I didn't like it ..
Vinyl tape (electrical) did the trick.
Offline bjbuchanan
« Reply #9 on: May 30, 2013, 06:55:57 PM »
I used that silicone plumbers tape that looks like wide electrical tape. No residue and sticks like a mofo to itself, I was/am pleased
Offline lucky
« Reply #10 on: May 30, 2013, 07:32:47 PM »
IT would be a lot of work and it needs to lay flat and cover all of the spokes.
Way too much work. 754's suggestion is much better. Electrical tape. Just use the whole roll.
« Reply #11 on: May 30, 2013, 08:29:35 PM »
C'mon, aren't rim strips like $1.95?!
Offline Shane72
« Reply #12 on: May 30, 2013, 08:36:21 PM »
This type of debate is common on KLR forums.
 ;D
Shane
I mount and balance MC tires--while-you-wait service by appointment.  Send me a PM.
Offline Dave Voss
« Reply #13 on: May 30, 2013, 08:37:48 PM »
+1 to what Stev-o said.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Offline goldarrow
  • one day, i'll be an
« Reply #14 on: May 30, 2013, 09:20:16 PM »
why spend the money when you can use duct tape if you already have a roll around the house
CB550 K0
« Reply #15 on: May 31, 2013, 05:49:33 AM »
Prefer to do things proper. When I order a tire, I simply order a tube and a strip at the same time, so its not like I'm ordering just a strip.
Bought a new DID rim for my Z1, a rim strip came with it. Why didn't they just include some tape?
Probably 'cause spoked rims were designed to use rim strips.
« Reply #16 on: May 31, 2013, 06:03:18 AM »
I have used a layer of tape and the old rim stip a couple of times. I wondered when I was laying the tape down though that when it turns to a goo on the adhesive in the future how hard it would be to turn the adjuster nipple later on if the spokes ever need an adjustment--Hmm      The little things in life to ponder.
« Reply #17 on: May 31, 2013, 06:07:27 AM »
I got the plumbers tape bjbuchanan is talking about - used it for wire harness - but I can see how well it would work for the wheel too.
« Reply #18 on: May 31, 2013, 06:22:49 AM »
jesus #$%*ing wept!just use a new proper one you cheap arse,,ill bet you use both sides of toilet paper aswell?
bollingball
« Reply #19 on: May 31, 2013, 07:02:19 AM »
Don't you wash it out and reuse. We just keep the corn cobs in warm water. Nice and soft ;D
« Reply #20 on: May 31, 2013, 07:05:10 AM »
Somedays you just sre not near a rim strip.. Plus some shops dont always have them.....and smetimes they move around or split..
« Reply #21 on: May 31, 2013, 07:19:48 AM »
Offline bjbuchanan
« Reply #22 on: May 31, 2013, 11:47:08 AM »
Couldn't get a rim strip and my new "good" one broke apart just by practically looking at it, so there the right way ::) local places didn't have it, they all said why didn't you order one
1.50 for a strip, 8 for shipping and wait a week for it or just use a pliable tape that leaves no residue behind?
Offline cosmicvision
« Reply #23 on: May 31, 2013, 12:24:16 PM »
Bustin me up over here, lol
But honestly, sometimes if you're just tryin to get back in the saddle and you live out in the sticks like me, 30 minutes away from any real shop, and it's Sunday & the shop's closed anyway...it's good to know that you can make a veritable substitute from household materials. Done it several times on bicycles so I figured it would be no different...700c x 23 bike rims are juiced up to 100psi and tape still gets ya down the road. Party on Garth
-Joshua
1974 cb550 - back of the garage for now
1979 cb650 - daily rider, mac 4-2, clubman, murray's carbs, guiliari type seat
