Author Topic: Confused about right-hand control housing (model?)  (Read 1031 times)
Offline Dangus
« on: May 30, 2013, 07:16:46 PM »
Hi,
Here a pic of the bottom of my right-hand control housing. The throttle hold for cable B (one closest to the driver) is larger than the other. I have four throttle cables, but they are all too small for the larger openning. Is there a specific type of cable that I need to buy? Anyone familiar with what this model this housing is from?
Thanks
Offline SohRon
Re: Confused about right-hand control housing (model?)
« Reply #1 on: May 31, 2013, 07:57:10 AM »
It's a stock, standard pre-'76 control base.  Right is the pull cable, left is the push cable. If your cables don't fit, I'd suspect that you don't have the right cables.
The push cable has an adjustment that screws into the base, which explains the differences.
« Last Edit: May 31, 2013, 08:55:14 AM by SohRon »
Offline Dangus
« Reply #2 on: May 31, 2013, 09:28:03 AM »
Hmmmm! I must be missing a piece then, cause I can only find cables with the same diameter of screw for the bottom of the base. A separate adjustment piece would explain it, but does not appear in any diagrams or parts lists. Puzzling.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: May 31, 2013, 10:13:35 AM »
The two throttle cables are different, one is specifically for pull and the other push. They have different sized ferrules.
Offline SohRon
« Reply #4 on: June 01, 2013, 12:55:43 AM »
A separate adjustment piece... does not appear in any diagrams or parts lists. Puzzling.
That's because it's an integral part of the push cable and wouldn't be listed seperately. Sounds like you need to purchase the correct cables.
Offline Dangus
« Reply #5 on: June 01, 2013, 08:54:37 PM »
Thanks everyone! I will be getting the correct cable over the next few days.
