Author Topic: Cb750F Low Boy  (Read 5731 times)
Offline fdbrat
Cb750F Low Boy
« on: May 31, 2013, 08:31:45 PM »
Lots of tabs shaved. Iron head tank.
I'm going low. And I'll be takin pix as I go.
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
Re: Cb750F Low Boy
« Reply #1 on: June 01, 2013, 12:34:33 PM »
Cool looks like an FX tank.. Is that a bicycle light or spotlamp..?
Offline fdbrat
Re: Cb750F Low Boy
« Reply #2 on: June 01, 2013, 10:32:23 PM »
Actually it's a moped light. Hahaha. For now it's just sitting there.
I'm going to the swap meet tomorrow to look for a proper fender.
Ill take pix tomorrow of the top tree. I shaved the #$%* out of it and smoothed it out. I'm pretty stoked on the way it came out. First try at that kinda thing. I'm proud of me.
« Last Edit: June 07, 2013, 01:21:48 AM by fdbrat »
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline fdbrat
Re: Cb750F Low Boy
« Reply #3 on: June 07, 2013, 01:14:36 AM »
Well I removed the lower bolt on the shocks and set them loosely on the chain adjuster to get a reference on the height I'd like.
I measured and its just about 10" and 1/16 of an inch.
I found these os twisted struts that match that exact length.
Bought them on eBay.
And last weekend I bought a fender off mr Hicks at the swap meet.
Sold it to me for $25!
Can't wait till the struts show up.
Very excited. :)
« Last Edit: June 07, 2013, 01:18:21 AM by fdbrat »
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline fdbrat
Re: Cb750F Low Boy
« Reply #4 on: June 07, 2013, 01:17:20 AM »
Here are the struts.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline db22
  • Old and in the way.
Re: Cb750F Low Boy
« Reply #5 on: June 07, 2013, 11:58:40 AM »
I like your thinking -- will be following.
1975 CB550K (rider)
1975 CB550K (shaping up, slowly)
I may be goin' to hell in a bucket, but at least I'm enjoyin' the ride. . .
Offline fdbrat
Re: Cb750F Low Boy
« Reply #6 on: June 08, 2013, 06:34:10 PM »
Struts just came in the mail. They are installed yet I need to hit the hard ware store to get some bolts and nuts.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline fdbrat
Re: Cb750F Low Boy
« Reply #7 on: June 08, 2013, 06:36:19 PM »
Here is a close up of the top tree after being shaved cut and filed. Needs a bit more but looks pretty good.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline fdbrat
Re: Cb750F Low Boy
« Reply #8 on: June 09, 2013, 08:14:52 PM »
Here is a bit of the old photoshop at work.
I really dig the chevy orange rims. I like the red but you see it quiet abit.
I dig it.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline fdbrat
Re: Cb750F Low Boy
« Reply #9 on: August 03, 2013, 10:47:40 PM »
Engine in, forks lowered, cleaned up a bit.
Slowly but surely.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline SOHC Digger
  • I'm not an
Re: Cb750F Low Boy
« Reply #10 on: August 04, 2013, 05:51:00 AM »
Lookin good so far.  Orange rims would be tight.  Nice job on the upper tree too!
Offline fdbrat
Re: Cb750F Low Boy
« Reply #11 on: August 04, 2013, 10:15:08 AM »
Thanx I'm doing my best. I know what I want it to,look like and I'm chipping away at it.
I am having a hard time finding the correct specs for float height.
I've seen so,many diffrent heights. And I I know this being a cb750f1 the floats are set different than a standard model.
I've searched but I keep getting mixed information.
Any suggestions would be great.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline BPellerine
Re: Cb750F Low Boy
« Reply #12 on: August 04, 2013, 06:11:26 PM »
tank looks nice on there kinda shows the engine off much trouble fitting?bill
1978 CB 750K ard and webers
another anfob
Offline Bankerdanny
  • Endeavor to persevere
Re: Cb750F Low Boy
« Reply #13 on: August 05, 2013, 11:40:08 AM »
That rear tire needs to go back or the fender needs to come forward a couple inches. The centerline of the wheel isn't matching the arch in the fender. I like the overall direction though.
Offline SOHC Digger
  • I'm not an
Re: Cb750F Low Boy
« Reply #14 on: August 05, 2013, 11:57:22 AM »
+1.  I'd lengthen the swing arm; it'll add to the bike looking low.
Offline Bankerdanny
Re: Cb750F Low Boy
« Reply #15 on: August 05, 2013, 01:49:05 PM »
Generally I don't understand the point behind the 16" rear wheel conversion you see on lots of 750's that have been rescued from decades in the back of someones shed. But in the case of this bike, a longer rear swingarm plus a 16" wheel and fatter tire would really help make the look.
Offline fdbrat
Re: Cb750F Low Boy
« Reply #16 on: August 05, 2013, 04:52:35 PM »
The fender is just in there via friction fit. You're right it will be coming down a bit.
The tank is an Ironhead tank. I removed the two bars on the spine. Fits nicely.
I would l much rather have extended the swing arm with stock shocks. The swing arm that's on ther isn't my favorite. I'd prefer to extend a round tube one instead. The square one is kinda blahh.
As for a 16" wheel... I like the 18" because it gives good purpose to having the fender come up higher. Gives it sexy curves.
Thanx for the input fellas. The main goal is to get it running. Wiring it from scratch.
Going battery less. I already have a Dyna s ignition for it.
Can't wait to grab the girl and just ride nowhere.
« Last Edit: December 10, 2013, 10:58:41 PM by fdbrat »
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline Bankerdanny
Re: Cb750F Low Boy
« Reply #17 on: August 06, 2013, 08:24:49 AM »
PM Hondaman to confirm, but I believe that the 550 swingarm is actually longer than the 750, so you might be able to get the longer round tube swingarm that way.
Offline fdbrat
Re: Cb750F Low Boy
« Reply #18 on: October 30, 2013, 12:16:40 PM »
Updat:
New used pipes
New grips
And a New Sullys 2 up seat.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline fdbrat
Re: Cb750F Low Boy
« Reply #19 on: November 20, 2013, 08:45:37 PM »
Well last night I finished the wiring. I have spark. I need to top off the oil. Install new plugs and caps. Relocate the coils, finish the tank. Add lighting and install brake line, and ride the #$%* out of it.
« Last Edit: December 11, 2013, 08:26:25 AM by fdbrat »
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline fdbrat
Re: Cb750F Low Boy
« Reply #20 on: December 10, 2013, 10:49:39 PM »
Update:
It is turn key running. I have installed some Lester mags I picked up for $100.
And... I need brakes.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline fdbrat
Re: Cb750F Low Boy
« Reply #21 on: December 10, 2013, 10:55:07 PM »
More pix
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline JoeHip
Re: Cb750F Low Boy
« Reply #22 on: December 10, 2013, 11:11:31 PM »
Sweet !
'76 750F1
Offline ogsmakdade
  • bike newb
Re: Cb750F Low Boy
« Reply #23 on: December 11, 2013, 05:31:39 AM »
lester mags for $100?  you lucky dog!  :o
Everyone thinks Chuck Norris is bad, but Chuck Norris has not meet Lucky either.  Lucky will round house kick Chuck back to 1969 and pop a wheel with the 1st sandcast while shotgunning a PBR!
My "build" http://forums.sohc4.net/index.php?topic=126537.0
Re: Cb750F Low Boy
« Reply #24 on: December 11, 2013, 06:23:40 AM »
Yeah. What he said.
