Author Topic: RS34 Tuning and General Information  (Read 15123 times)
Re: RS34 Tuning and General Information
« Reply #25 on: August 08, 2023, 01:31:50 AM »
Seems to be as my TMR, under side inlet side of throttle.
But these are more visible.
You have to adjust by feel.
1/8 turn make big difference on my Mikuni TMR32.
I seated all lightly. Photo of all with telephone.
Later fine tuned all after final photos when I knew that open 3/4 turn was the best setting. Compared photos and saw that one was 1/32 turn wrong despite my very careful adjustment.
Easy they could differ 1/16. Sometimes even 1/8.
I used a small screwdriver I have cut down the plastic handle on.
I have another short one for main jet.
A 3rd one for pilot jet.
They cannot be long when changing or adjustin with carbs on
Fuel screw and pilot jet screwdrivers trimmed on a bench grinder to fit the screws as good as possible.
From a kit of small screwdrivers with one bigger handle to mount. All in a small box.
My adjusted screwdrivers.
Main jet - black
Fuel screw - yellow
Pilot jet - red
« Last Edit: August 08, 2023, 01:49:21 AM by PeWe »
Offline Ellz10
  • ZZ
  • Knowledge is Power
« Reply #26 on: August 08, 2023, 08:52:17 AM »
Main jet - black
Fuel screw - yellow
Pilot jet - red
Perfect, thanks Pete!
Is there a set standard for where they should be placed to start adjustments or no?
Because my air/fuel mixture is WAY off and I don't understand which way to turn the screws or what needs to be adjusted after those screws are turned, ect.
It's all very complicated and I'm trying to understand it - I want and need to understand it.
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
« Reply #27 on: August 08, 2023, 09:04:51 AM »
See Mikes reply #14
Offline Ellz10
  • ZZ
« Reply #28 on: August 08, 2023, 07:21:25 PM »
See Mikes reply #14
Oh so he was referring to the air/fuel mixture screws when he talked about turning them starting at 1 turn out?
I didn't realize that's what he meant!
Offline Ellz10
  • ZZ
« Reply #29 on: October 05, 2023, 07:54:07 AM »
See Mikes reply #14
Just to reiterate, I should turn those screws all the way in til they stop and then turn them out 1 full turn as a starting point?
Should all 4 screws always be turned out the same amount when making adjustments?
« Reply #30 on: October 05, 2023, 09:02:34 AM »
See Mikes reply #14
Yes, all same.
My TMR32's are very sensitive in this matter.
They are located at the bottom pointing downwards.
All softly closed.
I finally took photos on all 4. Phone selfie camera. Blurry when too close but possible to see.
Adjusted to what I had found work. Photos again and saw that one carb was slightly different. Adjusted.
This was the final adjustment when everything ran fine. A kind of carb sync.
Offline Ellz10
  • ZZ
« Reply #31 on: October 06, 2023, 06:06:23 PM »
When turning these screws to make adjustments, which way equals what?
If I start them all out at one full turn, what would turning them out further do - make it run more rich or more lean?
« Reply #32 on: October 06, 2023, 09:12:47 PM »
Fuel screws, more fuel when out.
Offline CB750R
  • 77 CB750F
« Reply #33 on: July 06, 2024, 11:52:55 PM »
I’m still working on my RS34 but wanted to share that I found a flexible extended “rack” or main idle adjustment screw on eBay. I find having the rack idle screw extremely useful while still sorting out your jetting
