Author Topic: Crunchy chain. Yikes.  (Read 934 times)
Offline thelowmax
« on: June 02, 2013, 02:23:02 PM »
My chain seems to have developed a worrying symptom. As it rotates on the rear sprocket, it makes a crouching/snapping noise. It seems like it happens in a different spot on the chain each time, though close. The chain issue is caused by the chain snapping out of alignment with the sprocket, as if the sprocket had a worn spot or was bent. This is strange because the wheel is straight, as is the sprocket. Before I get a new chain/sprocket set, is there anything I could be  missing?
What am I doing and why am I doing it? Those are excellent questions.
'72 Amen Savior/'77 CB750K Chrome/Da Bhudda(project)
'73 CB750K Green/El Verde (beat)
'76 CB750K Red/The Cinnabomb (sweet)
'77 CB750K Black (frame and parts) CANNIBALIZED
'77 CB750K Dark Purpley/Scooty Puff, Jr. (la beast)
'78 CB750K Black (struggling) SOLD
'78 CB750K Blue Flake/CiocioSan (minty)
'81 CB750C Poiple/Barbie'sDreamMotorcycle SOLD (darnit!)
'89 Trek 21" 21 speed Green/YaBiatch (the wife)
Converse One Stars size 8.5 Black/Sneaks (suede)
Offline Schnell
Re: Crunchy chain. Yikes.
« Reply #1 on: June 02, 2013, 03:06:52 PM »
Alignment?
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #2 on: June 02, 2013, 04:37:14 PM »
Its kinking, to clean it up , lube each link where the plates slide against each other..one side, then the other all from inside the chain,,,,ie ABOVE the lower run..then a drip on each roller..
 Rotate it a few times or go for short easy ride.  Once its lubed again..You can actually see what you have left .
« Reply #3 on: June 02, 2013, 04:37:41 PM »
Check the countershaft sprocket also while your checking stuff out,they are smaller and turn more and get worn out. How old is the chain and is it lubed well ? Any other mods on the bike like wheels etc over the years ?
Offline Shane72
« Reply #4 on: June 02, 2013, 06:06:00 PM »
My chain seems to have developed a worrying symptom..... Before I get a new chain/sprocket set, is there anything I could be  missing?
Unless the drive set is fairly new, I would tend to rely on your initial assessment and self-recommendation.
Any time these components start making (crunchy, popping, grinding, whining, rhythmic) expensive noises, I replace them.
Breaking a chain at 50mph on the way home from a midnight shift and popping a hole in the case has affected my judgement in these matters.  YMMV.
All the best,
Shane
I mount and balance MC tires--while-you-wait service by appointment.  Send me a PM.
Offline thelowmax
« Reply #5 on: June 03, 2013, 01:31:42 PM »
"Expensive noises". Classic. I'll be using that one. ;)
