Author Topic: CB550 carb manifold O rings  (Read 823 times)
Offline Eddie
« on: June 07, 2013, 06:04:04 AM »
Anybody been able to change them with out removing air box and carbs ? Need to change mine as I can see tell tail signs..
Offline Bankerdanny
  • Endeavor to persevere
Re: CB550 carb manifold O rings
« Reply #1 on: June 07, 2013, 09:03:07 AM »
if you unbolt the box and the carb-box rubbers are liable enough I suppose that you could move the whole assembly back an inch or so and get sufficient room to remove the o-rings.
But can you get to the lower manifold bolts with the carbs on the bike?
It's worth a try. Worst case is you have to pull the airbox to get enough room to move the carbs back.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: June 07, 2013, 09:11:50 AM »
Just remove the venturi rubbers and nuts holding the carbs on and you should be able to pull the intakes away from the head by an inch. Getting old o-rings out is the hardest part. Maybe a dental pick or some similar tool. Once you can do that putting new ones back in is a cinch.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline NShahdadi
« Reply #3 on: June 07, 2013, 09:11:50 AM »
I'm in the same situation.
Let me know if you have any luck. I've been thinking about trying the same thing. It'd be nice to have a consistent idle...
1976 CB550K
Offline Eddie
« Reply #4 on: June 08, 2013, 12:47:49 AM »
sounds like it's worth a try. I'll post my findings..
Offline phil71
« Reply #5 on: June 08, 2013, 01:20:46 AM »
Not for nothing, you'd be crazy to do the o-rings and not verify that the carbs are spic&span.  bite the bullet, do the whole job, or chase gremlins for weeks.
Offline Eddie
« Reply #6 on: June 08, 2013, 08:22:08 PM »
already did the carbs... should have changed the O rings then. engine is pretty clean so after a very hot last summer you can see a little staining.
Offline phil71
« Reply #7 on: June 09, 2013, 09:07:18 AM »
if you had a fine right angle pick tool, you might fish 'em out, but I suspect you're gonna need the airbox boots pushed back
