Author Topic: CB550 fuel lines  (Read 8012 times)
Offline joemcvw1951
CB550 fuel lines
« on: June 09, 2013, 12:15:46 PM »
I went through a lot of previous posts..   I want to replace my fuel lines which are feeling pretty hard & brittle , and install some inline fuel filters. The posts are clear that the correct OEM spec is 5.6mm ID, but it seems that a lot of people have used 1/4" or 3/8". or 5/16" pretty interchangeably without issues.
Interested in pros or cons and a recommendation please
Offline phil71
Re: CB550 fuel lines
« Reply #1 on: June 09, 2013, 12:33:28 PM »
others will fit, and work, but the right size is a joy to work with.
« Reply #2 on: June 09, 2013, 03:49:31 PM »
5.5mm will stay on the barbs and not leak with or without hose clamps.
1/4 inch will work but you WILL need hose clamps to squeeze it down properly and reliably.
I have used 1/4 inch hose and regretted it.
Why do you want inline filters?  Honda includes a very good, reliable, and self cleaning filter for most of its models.  Some have a sediment bowl to  rinse out once in a blue moon.  It is especially difficult to use an in line filter and keep the constant gravity fall routing as the bike really should have.
Offline phil71
« Reply #3 on: June 09, 2013, 04:11:32 PM »
I second that whole post. If you've torn your original screen, replace it. Inline filters are for quitters.
Offline joemcvw1951
« Reply #4 on: June 09, 2013, 05:40:26 PM »
I had a lot of rust in the tank , since cleaned with the Yamalube system , I thought the inline filters might be a good precaution ?
Offline davidtime
« Reply #5 on: June 09, 2013, 05:48:36 PM »
Know of a good place to get the 5.5 mm?
Offline Tews19
  • I am no
« Reply #6 on: June 09, 2013, 07:30:28 PM »
Ebay. Guy sells 32 inches for 16 bucks. In search tab on ebay type in 5.5mm fuel line
1970 Honda CB750 survivor.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #7 on: June 10, 2013, 07:26:57 AM »
I ran a Mr. Gasket glass in-line filter with a replaceable element on my 550. Absolutely no issues with fuel flow.
Offline iron_worker
« Reply #8 on: June 10, 2013, 08:12:38 AM »
Go to a ATV/snowmobile/dirt bike shop and get yourself some 7/32" fuel line.
7/32" = .219"
5.5mm = .217"
I got 10' for $7.
IW
Offline new2bikes-again
    • wellandpond.com
« Reply #9 on: June 10, 2013, 08:23:24 AM »
What if he has this petcock and screen? I haven't been able to locate this tube and screen. I don't want to be a quitter who uses inline filters!
I'm not sure which SOHC4 Joe has, but if he has the same petcock I have, I feel bad for him.
Offline iron_worker
« Reply #10 on: June 10, 2013, 08:43:04 AM »
I really have no problem with inline filters like a lot of people here seem to. You really do have to make sure that the lines only slope downwards towards the carbs though or you may trap air in the lines and starve the bike for fuel. The fuel filters make this much more difficult to do within the limited space... but not impossible.
IW
Offline joemcvw1951
« Reply #11 on: June 10, 2013, 09:42:20 AM »
I have the petcock with the screen and bowl below the valve
« Reply #12 on: June 10, 2013, 09:56:33 AM »
Must be a 74, or a tank from that or and earlier Cb500.
I like those, too.  If it fits through that screen mesh, there is nothing to stop it traveling all the way through the carb and out the exhaust pipe.
The screen cleans itself.  Big particles go to bottom of bowl, dropping off the screen above.  It really ought to take quite a while to fill the bowl completely and in the mean time, you will still get full flow through the filter.  In line filters reduce flow as they trap particles, so there will be some odd engine behavior just before they clog completely.  You must check in lines frequently if they are actually doing their job, or replace them at some unspecified routine interval, if their "preventive" nature is to be preserved.
« Reply #13 on: June 10, 2013, 10:00:27 AM »
That's the 75-76 type.
STRAINER SET    16952-341-671
The last one I bought was from the Honda dealer.   Have they been discontinued?
    • wellandpond.com
« Reply #14 on: June 10, 2013, 09:34:48 PM »
I forgot to check David Spears, but Bike bandit, Z-1, & Honda, only show the type that you described earlier (TwoTired). The bowl that hangs down.
I found that ebay fuel line. If I could locate that tube & screen, I'd ditch the filters and run new line.
Did you guys see that post about these inline filters not liking moisture? The ones with the brass mesh element? I think HondaMan started it?
Offline goldarrow
  • one day, i'll be an
« Reply #15 on: June 10, 2013, 09:50:15 PM »
check here for 7/32" fuel line. they have clear and colored fuel lines.  awhile back I bought a whole bunch of these to offset the shipping price, then shared with other members on the forums.  worked out pretty well
http://www.alssnowmobile.com/PRODUCTPARTS.ASPX?pn_deptid=304
« Last Edit: June 10, 2013, 09:56:25 PM by goldarrow »
CB550 K0
« Reply #16 on: June 10, 2013, 10:35:22 PM »
I put the part number I posted earlier (16952-341-671 ) into Google.  I didn't check stock at these sites, though.  But, they list it.
http://www.cmsnl.com/products/strainer-set_16952341671/
http://www.gearhead.com/honda-16952-341-671.html#/s/HOM//16952-341-671/1
http://www.partzilla.com/parts/detail/honda/HP-16952-341-671.html
http://www.ereplacementparts.com/strainer-set-p-1348176.html
http://www.ebay.com/itm/Honda-CB-750-Four-K6-Benzinhahn-Filter-Set-Original-/221205424086?pt=Motorrad_Kraftradteile&hash=item3380dee7d6
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #17 on: June 11, 2013, 12:09:18 PM »
Easy there big fella! My intake filters are failing me constantly. I clean them, check them, clean the tank and I still get crud in the carbs. Over flow drain leaks and a crappy running motor are the symptoms. I had to completely drain and clean my tank every year, take the bowls off the clean them and the pilot jets. This gets old. Once I put inline filters on no problems. I still see the crud that comes from the gas pump in the clear filters, its no wonder our bikes even run with this crap. And no i don't go back to the same pump. Not even the same company.
« Last Edit: June 11, 2013, 12:11:50 PM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
