Logo merchandise is available at the SOHC/4 Shop
I want to do an oil change and install new seals on my 71 cb750 and need to know if 72 to 76 fork seals are different than the 71s.Thanks!
Quote from: chewbacca5000 on June 10, 2013, 07:32:43 AMI want to do an oil change and install new seals on my 71 cb750 and need to know if 72 to 76 fork seals are different than the 71s.Thanks!Check the parts fishies for common part numbers. They may also list the dimensions of the seals. I think there were changes in the dimensions between K1 and K2. The ID is the same at 35mm, but the OD and the height may have changed, to make them more stable and less prone to leaking. OCICBW
A 35x48x11 will fit in where a 13.2 is called for. Maybe not the other way around. If the newer 13.2 will fit your leg, that'd be the one to use.You may be able to read the dimension on the old seal, or measure the inside leg when the seal is out.
Quote from: MCRider on June 10, 2013, 10:44:12 AMA 35x48x11 will fit in where a 13.2 is called for. Maybe not the other way around. If the newer 13.2 will fit your leg, that'd be the one to use.You may be able to read the dimension on the old seal, or measure the inside leg when the seal is out.Not if the seal race is only 46mm. The issue isn't the thickness of the seal but the OD. The 11 will fit where the 13.2 is called for if using the spacer for the 11.
