Author Topic: Help 1972 cb500 right control on a 1975 cb550  (Read 2169 times)
Offline Mcwilliams570
« on: June 11, 2013, 10:04:01 AM »
Hello all working on finishing the wiring and have run into a problem with the right hand control. The bike is a 1975 cb550 and I am using turn signals, rear tail light, left hand control and right hand control off a 1972 cb500. I have got almost everything working except the right blinkers come on dont blink probally a grounding issue should be to hard to figure that one out but I cant get the starter button to work. The 500 right hand control is a bit different than the 550 control as far as the wiring goes.
cb500 right hand control
-yellow/red
-black
-black
-black/white
-brown/white
-dark blue
-white
the wiring diagram I have for the cb550 is
headlight switch
-black
-brown/white
emergency switch
-black
-black/white
start switch
-green/red
-red yellow
rear stop switch
-black
-green/yellow
The 550 has one more connection I am not sure what I am missing here or what I need to do to make this switch work any help or suggestion would be greatly appreciated.
Thanks Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Vinhead1957
Re: Help 1972 cb500 right control on a 1975 cb550
« Reply #1 on: June 11, 2013, 02:19:33 PM »
Usually it is the ground from the turn signal that is the problem! I added an extra ground wire from each signal
Offline chewbacca5000
  • I polish covers!
« Reply #2 on: June 12, 2013, 04:06:17 AM »
What color is the start button wire?  If the start button wire is white it probably just goes to ground. That is how it is on my 1971 cb750.  On my 1973 The yellow w/ orange stripe connects to a matching wire in the head light bucket.
« Reply #3 on: June 12, 2013, 04:47:55 AM »
I will look when I get home chewbacca I think the white is a headlight one.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: June 12, 2013, 05:34:53 AM »
White and blue are for the headlight. Brown/white for ancillieries. Black/white for kill switch.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: June 12, 2013, 08:16:58 AM »
Lesters got it. Blue and white are for High and Low beams. There is no hi-lo HL switch on the 550 RH control. The 500 had it.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #6 on: June 12, 2013, 08:23:12 AM »
Yeah I got the lights working its the starter button that's not working out with the 500 wiring. Thanks for the input guys when I get home today will check it out some more.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
« Reply #7 on: June 12, 2013, 08:25:45 AM »
The starter switch on the 500 has no green/red.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline MoMo
  • Ride like you're invisible
« Reply #8 on: June 12, 2013, 08:34:52 AM »
Matt, what you're going to do is use the y/r wire   from the switch as the ground for the solenoid then run a jumper from the black wire out of the ignition switch to the other side of the solenoid.  That is what I did on one of my 400 fours that used an early model r/h switch...Larry
« Reply #9 on: June 12, 2013, 08:41:14 AM »
What Mo Mo is saying is the connections at the starter solenoid are different:-
The 550 has a ground wire and a powered when button pushed wire
The 500 has a power wire and a grounded when button pushed wire
