Author Topic: wiring aftermarket starter solenoid  (Read 871 times)
Offline zenocchio
« on: June 12, 2013, 01:31:05 pm »
I bought an aftermarket starter solenoid, that came with different colour coded wires.
I know that the two main posts can be hooked up to battery and starter motor independently, but what about the wires? is there going to be a difference if one is connected to fuse or starter button?
thanks!
Offline Jasondo
Re: wiring aftermarket starter solenoid
« Reply #1 on: June 12, 2013, 07:08:34 pm »
It probably has a yellow/red and a yellow/green?  Run the red wire to th starter button and the green to the fuse block.
Offline zenocchio
« Reply #2 on: June 12, 2013, 10:08:33 pm »
you are right!
the colour code is exactly as you said, red-yellow and green-yellow.
do you have the same one?
Offline Jasondo
« Reply #3 on: June 13, 2013, 02:14:07 am »
Yeah it was from eBay an works fine.
