Author Topic: Shaved oil filter housing  (Read 4586 times)
Re: Shaved oil filter housing
« Reply #25 on: August 11, 2006, 08:46:07 PM »
Looks good mate! Cheers, Terry. ;D
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #26 on: August 12, 2006, 03:33:39 AM »
I wonder to what extent the finned cover dissipates heat better than the smooth ??? I assume they made the change for this reason ???
I think that's the reason, but I don't have any hard data on cooling.
I'm sure a cooler with one of Terry's adapters would take care of any problems. ;) ;D
« Reply #27 on: August 12, 2006, 06:24:09 AM »
I thought the reason was because they(smooth) cracked if overtightened just a little.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #28 on: August 12, 2006, 07:23:56 AM »
I guess it would strengthen it also. This is the reason they added webbing around the bolt hole on the inside as well.
« Reply #29 on: August 13, 2006, 01:58:18 AM »
I went out and measured the thickness of the material and it's a tad over 3mm, which is quite thick, I don't know how much is removed on the lathe to make it round, but if it's just a "skim", it should be fine. I'd watch those "ridges" though, they only serve to remove material and weaken the assembly. I still reckon it looks good though, of course as Bob mentioned, it'd look better attached to one of my oil coolers, ha ha! Cheers, Terry. ;D
