Author Topic: Best way to adjust cam chain?  (Read 7465 times)
Offline M 750K6
Re: Best way to adjust cam chain?
« Reply #50 on: April 08, 2024, 01:49:14 AM »
I guess that is a version of Bryan's pressure on the kickstarter method, but I'd need to take all 4 plugs out to take the compression away, in order to do what you suggest. OK if they're already out, of course.
I like the suggestion of, before tightening the adjuster, pushing the tensioner from behind, then releasing, to check it is free to move. On a 750, I don't find the factory method of 15 degs ATDC too difficult.
« Reply #51 on: April 08, 2024, 01:56:48 AM »
Remember that i used to do this in a workshop on timed servicing so you got into a routine of order of doing things
Offline M 750K6
« Reply #52 on: April 08, 2024, 02:59:57 AM »
👍 I will try the kickstarter method. Undo adjuster, check it is free. Then I can see how it's easy to hold the kicker with a left hand and tighten the adjuster with the right. No points cover, nor valve cap removal.
« Reply #53 on: April 08, 2024, 04:25:12 AM »
Correct, and you SHOULD NOT be turning the engine with the nut inside the points cover anyway
Offline M 750K6
« Reply #54 on: April 08, 2024, 09:19:11 AM »
Oh, I have been, to adjust the points and timing. How should we turn the engine over?
« Reply #55 on: April 08, 2024, 01:46:57 PM »
Kick start or bolt under generator cover.
It is just allowable to use the big nut when all sparkplugs are removed
Offline willbird
« Reply #56 on: April 09, 2024, 08:42:20 AM »
I think it is really better overall to not use it all. Saw a video on setting valves where the guy showed putting bike in 5th gear and using the rear wheel to roll the engine over. Have not done it that way yet myself but it seems to make sense. He might have been using a mirror to watch the rocker arms while doing this.
Offline Deltarider
« Reply #57 on: April 10, 2024, 12:00:53 AM »
I hesitate to communicate this, anyway... here goes. For the last 43 years I've turned the crank by its big nut under the points cover without removing the sparkplugs (engine cold!). At first with an adjustable wrench. There's a risk you will round the hexagon, so it's better to use a 23mm socket on a T-handle. There's still a risk you will round that hexagon, in Hondaspeak: WASHER, SPECIAL, but... the risk damaging the bolt must be a CB750 thing.
CB500K2-ED Excel black
Offline newday777
« Reply #58 on: April 10, 2024, 05:34:28 AM »
It is. Very different than your bike.
The 750 has a small diameter replaceable shaft that screws into the end of crank and is easily bent.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #59 on: April 10, 2024, 05:38:11 AM »
The advancer shaft on a 750, #8
Stu
My current rides
Prior bikes....
Offline jonda500
« Reply #60 on: April 10, 2024, 04:48:12 PM »
Looks to be M6 - same diameter as the 350/400/500/550 use. I also have been using that big nut to turn sohc honda engines for 40 years. Since hearing about the bent shafts in this forum I now usually make sure the plugs are out first.
John
A starter clutch thread:
« Reply #61 on: April 10, 2024, 05:16:25 PM »
The 750 bends the shaft making the timing erratic, the 500 etc can bend the bolt with the same result, just cos you ben lucky and not bent it does not make it a good idea
