Author Topic: Fork rebuild question specific to CB500  (Read 3114 times)
Offline jamesbekman
« on: June 14, 2013, 07:51:38 AM »
Hi Everyone,
So if you go to this link http://www.motorcycleclassics.com/mc-how-to/honda-cb500-fork-rebuild.aspx its pretty straight forward.
My question is something not addressed in the technical article and is specific to the CB500 front suspension, specifically the damper rod.
There seems no good reason for removing it at all although its cited as a step that should be taken.  Can someone shed light on why it would be a good idea to pull the damper rod?
I also have posted about not being able to find replacement fork tube nuts for the CB500 as they are no longer made and the bottom of the nut screws into the top of the damper rod.... I have been able to source them from someone at dotheton.com $54 a bit pricey but hey at least its possible to get them.
Thanks,
James
Offline jamesbekman
Re: Fork rebuild question specific to CB500
« Reply #1 on: June 14, 2013, 07:52:46 AM »
The fork tube nuts are machined.  Not NOS.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: June 14, 2013, 09:37:49 AM »
The only nuts on the fork hold the wheels on.
Are you talking about the allen head bolts at the very bottom of the lowers? I had to drill one to get it off, I just went down to my local True Value Hardware and bought some SS ones in similar size and copper washers. Worked like a charm.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: June 14, 2013, 09:58:07 AM »
Top nuts on the tubes.
Offline MotorFist
    • MotorFist
« Reply #4 on: June 14, 2013, 10:21:31 AM »
Hi Everyone,
When I rebuilt he forks on my cb500, there was a fair amount of sludge under the damper rods after I removed them.  I would say "a reason " if not "the main reason" for pulling them is to properly clean everything.  Also the damper rods themselves are easier to clean out when removed. The allen screws on the bottom can be hard to remove as Duanbob mentioned but any job worth doing, is worth doing right ;)
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline MotorFist
    • MotorFist
« Reply #5 on: June 14, 2013, 10:25:28 AM »
Are you talking about this nut that srews onto the damper and retains the spring?
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
  • 1977 CB550F2
Offline MotorFist
    • MotorFist
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: June 14, 2013, 02:03:22 PM »
You mean the caps? Or the bolts as Honda refers to them.
Frankly I don't know what he's talking about at this point.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
  • 1977 CB550F2
« Reply #9 on: June 14, 2013, 02:13:52 PM »
He might enlighten us one day.
« Reply #10 on: June 14, 2013, 02:23:40 PM »
also measure your springs to see how sagged they might be,this wasnt addressed during that fork tube replacement article.
Offline MotorFist
    • MotorFist
« Reply #11 on: June 14, 2013, 02:26:19 PM »
Good call Dave. I replaced my springs with some racetech springs and updated my steering head bearings. It made my front and very happy :-)
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
« Reply #12 on: June 14, 2013, 08:38:25 PM »
The very first 500 used 450 disc forks where the only thing stopping the front wheel and sliders coming off was the long rod all the way from the damper to the top nut!!
This was soon changed and a collar was welded into the bottom of the fork tube with a new style damper that bottomed on the collar instead of sliding all the way out, this type has to come out upwards and the long rod with locknut was discontinued along with the threaded hole in the top nut.
Yoou can modify a later top nut by simply drilling and tapping at the correct size (8mm I think)
« Reply #13 on: June 14, 2013, 08:46:00 PM »
their copper washer wasnt replaced or annealed either,you dont need to grab the damper rod with vice grips and tighten that lock nut down either,just nip it by hand and lock the top nut against it,it also wasnt explained to inspect the fork leg inside for scoring from perhaps the rusty tube going into it?4 out of 10 on that rebuild.
