Author Topic: Brake ID please. Nothing ordered matches...  (Read 3375 times)
Offline UFgatorEE
  • "Yoruichi," my Japanese mistress. 1978 CB550K
« on: June 14, 2013, 08:05:38 AM »
So come to find out, none of my brake rebuild parts match up so far.  Bleed screw is a 10mm instead of a 7mm, which I found a replacement for.  The pads don't match either.  Pads I bought have mounting indents, pads I need have mounting tabs.  I'm hoping my master cylinder parts line up.  EDIT: MC brake line bolt is a 12mm, IIRC.
If anyone can ID what bike these brakes are from so I can purchase proper parts, I'd really appreciate the help.  If anyone needs a new bleed screw or new pads, I wouldn't mind reducing the money loss...
Calipers have "Tokico 3" written on the bottom outside.
The pads:
and the Master Cylinder:
« Last Edit: June 14, 2013, 08:10:45 AM by UFgatorEE »
Re: Brake ID please. Nothing ordered matches...
« Reply #1 on: June 14, 2013, 08:13:05 AM »
what year/model bike do you have?
those appear to be an early K caliper and you'd need the EBC FA12 pads
MC is pretty standard.  order the rebuild kit for the same year of your bike.
Offline UFgatorEE
« Reply #2 on: June 14, 2013, 08:16:02 AM »
1978 CB550K.  So earlier model year.  Can you give an example for the parts fiche?  1975, maybe?  I don't know these bikes very well.
Also, doing an image search for the FA12 pads shows a proper back pad (not sure what to call it), but my piston  pad has a raised nub, and the photos don't show that.  Did they change that?
« Last Edit: June 14, 2013, 08:20:10 AM by UFgatorEE »
Offline UFgatorEE
« Reply #4 on: June 14, 2013, 08:34:31 AM »
I mean no disrespect, but I don't know what you want me to do with that link.  It takes me to a page where I have to choose a model, then I have to choose a year (model revision).  I've already stated I bought parts for my model that don't match.  And it's overseas.
« Reply #5 on: June 14, 2013, 08:39:36 AM »
none taken...The link is for you to look at the various types of 550's, find yours, and look up Honda part numbers for items you need.
Your caliper, however, does not look like its from your 78 550K.
The FA12 pads come with the 'nub' in the package.
Its actually a screw that fits into the top of the pad to keep it from rotating in the caliper.
what is overseas?
Duanob, dave500, and TwoTired are the members you want to chime in...
Offline UFgatorEE
« Reply #6 on: June 14, 2013, 08:41:14 AM »
The company you linked.  All the prices were in pounds, I think.
Anyways, I was browsing BikeBandit's fiches (I guess your reply hit home, but indirecty...lol).  Looks like a 1974 CB750K matches.
EDIT:  Which looks like it uses the FA12 pads.  Thanks!
« Last Edit: June 14, 2013, 08:44:09 AM by UFgatorEE »
Offline LesterPiglet
  • 1977 CB550F2
« Reply #7 on: June 14, 2013, 10:02:01 AM »
Weird e's are Euro.  £ is a pound.
I've never seen that ribbed caliper before.
EDIT I've just seen that caliper on a 750 k2
http://www.cmsnl.com/honda-cb750k2-four-usa_model14362/partslist/F06.html#results
« Last Edit: June 14, 2013, 10:53:39 AM by LesterPiglet »
« Reply #8 on: June 14, 2013, 10:11:01 AM »
yes, i did not intend for you to purchase from them.   just use that site to locate the part numbers for what you need, as i stated, then, google the part number, and find all the US dealers and prices.
Offline Dave Voss
« Reply #9 on: June 14, 2013, 11:02:50 AM »
I have a 1978 CB550K, and I just completed a brake rebuild last month, and I can tell you that the pads you ordered and received are correct for your make/model/year, however the brake caliper in your picutres is not the stock caliper, apparently it was changed at some point.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
  • 1977 CB550F2
« Reply #10 on: June 14, 2013, 11:12:58 AM »
See my previous post.
« Reply #11 on: June 14, 2013, 11:18:32 AM »
Exactly.  I have two 750K1 calipers just like that on my K8
Offline Lost and Confused
  • Bob
  • An old fart !!
« Reply #12 on: June 14, 2013, 06:54:32 PM »
Looks like my 74 750k. Looks like a lower brake line might be in order?
Bob
« Reply #13 on: June 14, 2013, 08:21:25 PM »
Not the correct caliper for your bike, somebody in the past has fitted 750 parts. you need to check the diameter of the disc to see if that has been changed as well, possibly even the forks and wheel
« Reply #14 on: June 14, 2013, 08:37:58 PM »
That is a '73-'76 750K caliper; the '72 and earlier had a "C" shaped mounting bracket instead of the "T" shaped one pictured. The disc is a 500; there is a sizable gap between the outer diameter of the disc and the underside of the caliper. The 750 disc is about 3/4" larger in diameter. About 3/8" of the pads are above the edge of the disc with this configuration, rendering that area ineffective. The best solution, IMHO, would be to fit a matching 750 disc. It will bolt right on to the 550 wheel, and will be an upgrade over the 550 setup.
« Reply #15 on: June 14, 2013, 08:42:04 PM »
As I remember it all the calipers were the same size just the bracket changed, best overall solution would be to fit a 500 caliper complete (same as 500four, 500 twin, 400 four and 360 twin)
« Reply #16 on: June 14, 2013, 08:47:33 PM »
I disagree. Why not just step up to the larger 750 disc, since he already has the 750 caliper? Is this case, bigger is better. ;)
Offline UFgatorEE
« Reply #17 on: June 15, 2013, 12:04:02 AM »
I noticed the odd pad wear, but it didn't click until you said something. A better brake is good.  The brake leaves a lot to be desired compared to my last bike (my last bike had two 4-pot calipers).  Thanks for the heads up.
Offline Bailgang
  • Scott
  • Indiana
« Reply #18 on: June 15, 2013, 02:25:23 AM »
Interesting idea but will the 550 caliper mounts accommodate the the larger O.D. 750 rotor? If so then I might just give that a try on my 550 because I have all the front brake hardware from a 77 750K. RATS!! come to think of it no I don't because I just recently took the 750 rotor I had, cross drilled it and gave it to my kid for his 750. Oh well but if everything will interchange then I'll just pick up another rotor off ebay.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Dave Voss
« Reply #19 on: June 15, 2013, 07:34:19 AM »
From the original poster's pictures, the caliper and mount were changed at the same time, and possibly the pivoting T-bracket as well, in which case fitment of a larger diameter brake rotor would depend on whether or not the location of the mounting holes on the fork legs are the same between the 550 and 750.  Perhaps the fork legs were also swapped in this case, could be the results of being put back together from alternate parts following an incident, accident, etc. at some point.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
« Reply #20 on: June 15, 2013, 09:13:20 AM »
If its a 500/550 caliper mount and sliders the 750 disc is too big
Offline Bailgang
  • Scott
  • Indiana
« Reply #21 on: June 15, 2013, 10:12:52 AM »
I have all the pivoting and mounting hardware including caliper from a 750K that I would need but it's the height of the mounting holes on the fork legs that concern me, I'll check and see because I do have the 750 forks as well. Not crazy about the idea of swapping forks if that's what is needed to make it work because I'm just now wrapping up putting new progressive fork springs in the 550's forks.  :-\
Scott
71 cb350 twin
77 cb750 F2
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #22 on: June 15, 2013, 01:19:34 PM »
mrcycles.com   is another site you can check out.........you can compare different bikes in seperate windows if you need to cross reference part numbers.
MATT
Offline UFgatorEE
« Reply #23 on: June 15, 2013, 05:40:33 PM »
I couldn't tell you (and i doubt my dad could either) why the parts were interchanged.  My dad bought this bike as a barn bike, so the history is unknown.  He spent a lot of time restoring it, but he didn't know about the front brake until I asked him.
I think the benefits are minor.  Slightly larger rotor size (so more braking torque) and potentially better caliper cooling due to the heat sink shape.  The piston size is the same, so clamping force is the same.  It's the only part I ordered for the caliper that actually fit...
« Last Edit: June 15, 2013, 05:49:43 PM by UFgatorEE »
Offline UFgatorEE
« Reply #24 on: June 15, 2013, 05:46:58 PM »
Bob
I just noticed this post, and yes, a replacement hard line is in order.  It's a tight squeeze to get it to fit where it is.  It works (not sure if it's been tweaked to fit), but the ends screw in easily enough.  One thing I noticed is the rubber grommet on the fender is twisted to be more parallel to the floor, due to the higher routing of my current line.  I assume I can use a 750 hard line.  I'll have to find some pictures and/or get measurements.
