Author Topic: cam timing...grrrr  (Read 873 times)
Offline davesee
cam timing...grrrr
« on: June 14, 2013, 03:01:41 PM »
the picture is worth a thousand swear words.
when my cam mark lines up, my crank lines up slightly past the 1.4 T mark, just a bit off but noticeable. if i walk a tooth in the other direction i'm off by the same amount. all told i'm half a tooth out.
i'm assuming my cam chain has stretched and needs to be replaced. i'd like to do that at a later date. what will the effect on the bike be if i button it up as it lies?
is being out one way preferable to the other?
1980 honda cb650 with many weekends worth of modifications.
Offline lucky
Re: cam timing...grrrr
« Reply #1 on: June 14, 2013, 03:16:00 PM »
You should line up the cam the way the workshop manual says.
The electrical timing is independent.
That plate the points are on can rotate. So just get the cam in right and don't worry about it.
Is the cam lined up correctly?  That is the main thing.
Then set your points.
Offline davesee
« Reply #2 on: June 14, 2013, 03:35:46 PM »
okay...i used a pencil through the sparkplug hole to find TDC, and i moved the cam chain back one link on the sprocket, and now the cam timing mark is positioned correctly. am i right in assuming that the timing plate position will be corrected when i set the ignition timing?
Offline davesee
« Reply #3 on: June 14, 2013, 04:51:52 PM »
wait, no, i'd be wrong assuming that. i retensioned the tensioner and spun the crank a few times, and now things look a lot better.
Offline UFgatorEE
  • "Yoruichi," my Japanese mistress. 1978 CB550K
« Reply #4 on: June 14, 2013, 05:49:19 PM »
the crank turns 2x for every 1 turn of the cam.  So if you were one tooth off on crank, it would throw the cam off half a tooth.
Offline lucky
« Reply #5 on: June 14, 2013, 05:53:20 PM »
Was the #1 piston at TDC on the compression stroke?
Cam lobes both pointed down at 45ยบ angles when you put on the cam and chain???
